which engine is better
Old Jun 2, 2009 | 05:30 AM
feriotypeR's Avatar
Default which engine is better
well im gettin a d15b, but dont know which 1 to get. the one with dual vtec or the 130hp version? which 1 is better ppl? dont tell me to get a b, h, k series.
Old Jun 2, 2009 | 08:45 AM
CRtotheX's Avatar
Default Re: which engine is better
why don't you get d16z5 (d16a9) ? non-vtec 124hp(130hp)
Old Jun 2, 2009 | 08:24 PM
JDMCivic16's Avatar
get a JDM d15b single cam vtec or a d16z6
Old Jun 2, 2009 | 10:47 PM
CRtotheX's Avatar
Even though i probably will make many enemies, i wouldn't get a vtec, even though you get **** lots of performance parts, i just think it's overrated these days .
I'd get a D16 motor,and do the normal tune up and you'll have a good and affordable engine.
Old Jun 2, 2009 | 11:03 PM
Ruben19's Avatar
dual vtec
Old Jun 3, 2009 | 02:38 AM
feriotypeR's Avatar
thanks ruben, u seem to be the only person who knows how to answer a question
Old Jun 3, 2009 | 03:01 AM
civic-one's Avatar
Get the JDM 2 stage vtec. Had it before did pretty good until I went to a B.
Old Jun 3, 2009 | 01:45 PM
feriotypeR's Avatar
let me ask, what does the dual vtec do?
Old Jun 3, 2009 | 02:26 PM
civic-one's Avatar
Dual vtec. . . explains itself. It has two vtec engangment point. If you look up close there's two vtec solenoids on it.
Old Jun 3, 2009 | 04:13 PM
feriotypeR's Avatar
when do they both kick in?
Old Jun 3, 2009 | 07:00 PM
uberEFtuner's Avatar
Non Vtec is better. Power all the time! No need to wait for it to engage.
Old Jun 3, 2009 | 07:06 PM
feriotypeR's Avatar
why do ppl not answer the question that is at hand. I dont want to hear about other motors. just the 1s that are stated in the forum. plus non vtecs' have less power.
Old Jun 4, 2009 | 05:57 AM
Do some research, compare how much torque each engine has. You will notice there is not a whole lot of difference between them. Torque is a better measurement of power.
Answer:
I say non vtec and spend the money you saved on bolt ons.
Old Jun 4, 2009 | 09:37 AM
feriotypeR's Avatar
yeah, ok, thanks
feriotypeR's Avatar
I JUST WANNA KNOW WHEN THE DUAL STAGE VTEC KICKS IN
Old Jun 4, 2009 | 09:42 AM
feriotypeR's Avatar
[edit] D15B (3 stage VTEC)
3-stage VTEC
Found in:
1995-1999 Honda Civic VTi EK3 and Ferio Vi
Displacement : 1,493 cc (91.1 cu in)
Bore and Stroke : 75 mm × 84.5 mm (3.0 in × 3.3 in)
Rod Length : 137 mm
Rod/Stroke : 1.62
Compression : 9.6:1
Power : 128 hp (95.4 kW, 130 ps) @ 7000 rpm
Torque : 102 ft·lbf (14.2 kg/m, 138 Nm) @ 5300 rpm
Valvetrain : SOHC VTEC (3-4 valves per cylinder, depending on rpm)
VTEC Switchover : 2500 rpm (VTEC-E) & 6000 rpm (VTEC)
Fuel Control : OBD-2 MPFI
FirstCRX
Sep 22, 2014 12:09 AM
h4mza
Feb 22, 2013 10:13 AM
B18C5-EH2
14
Jan 19, 2005 08:00 AM
B18C5-EH2
Jan 17, 2005 04:00 PM
LordoftheAccord
Nov 16, 2001 08:38 PM
