which engine is better
well im gettin a d15b, but dont know which 1 to get. the one with dual vtec or the 130hp version? which 1 is better ppl? dont tell me to get a b, h, k series.
Even though i probably will make many enemies, i wouldn't get a vtec, even though you get **** lots of performance parts, i just think it's overrated these days .
I'd get a D16 motor,and do the normal tune up and you'll have a good and affordable engine.
why do ppl not answer the question that is at hand. I dont want to hear about other motors. just the 1s that are stated in the forum. plus non vtecs' have less power.
Do some research, compare how much torque each engine has. You will notice there is not a whole lot of difference between them. Torque is a better measurement of power.
Answer:
I say non vtec and spend the money you saved on bolt ons.
Answer:
[edit] D15B (3 stage VTEC)
3-stage VTEC
Found in:
1995-1999 Honda Civic VTi EK3 and Ferio Vi
Displacement : 1,493 cc (91.1 cu in)
Bore and Stroke : 75 mm × 84.5 mm (3.0 in × 3.3 in)
Rod Length : 137 mm
Rod/Stroke : 1.62
Compression : 9.6:1
Power : 128 hp (95.4 kW, 130 ps) @ 7000 rpm
Torque : 102 ft·lbf (14.2 kg/m, 138 Nm) @ 5300 rpm
Valvetrain : SOHC VTEC (3-4 valves per cylinder, depending on rpm)
VTEC Switchover : 2500 rpm (VTEC-E) & 6000 rpm (VTEC)
Fuel Control : OBD-2 MPFI
3-stage VTEC
Found in:
Rod Length : 137 mm
Rod/Stroke : 1.62
Compression : 9.6:1
h4mza
Feb 22, 2013 10:13 AM
B18C5-EH2
14
Jan 19, 2005 08:00 AM
B18C5-EH2
Jan 17, 2005 04:00 PM
