ecu to distributor problrm
Old Jul 29, 2009 | 06:11 AM
civic-one's Avatar
Default ecu to distributor problrm
If running and obd2 ecu are you able to use an obd1 dizzy with a dizzy harness. I tried using an obd1 dizzy with obd2 ecu the car wouldnt turn over but yet if I use the obd2 dizzy its starts. Or will this conclude that the problem is the conversion harness for the distributor?
Old Jul 29, 2009 | 06:26 AM
dephtone's Avatar
Default Re: ecu to distributor problrm
No you have to use an obd2 dizzy with an obd2 ECU. Or use a obd1 dizzy with a obd1 ecu. You can't mix and match as the ECU wires go to different spots pending on which obd it is.
Old Jul 30, 2009 | 06:00 AM
civic-one's Avatar
Ahhhhh! thank you very much I thought i needed to send an distributor harness back to its maker because it wouldnt turn the car over thanks again.
Redprelude98
Jan 9, 2009 11:46 AM
Adam West
May 8, 2006 03:47 AM
98JDM_Type_R
Aug 19, 2004 01:51 PM
C_I_V_I_C
Nov 5, 2003 05:26 PM
inline4
15
Sep 9, 2003 03:03 PM
