OBD1 or OBD2 distributor?
Old Aug 16, 2004 | 08:28 AM
98JDM_Type_R's Avatar
Default OBD1 or OBD2 distributor?
I'm going to be putting a 94-95 OBD1 B18C into my car w/ an OBD1 ECU. The wire harness that I'm using is 96-00 OBD Civic EX harness. What distributor do I use?
Old Aug 16, 2004 | 08:48 AM
-faded-'s Avatar
Default Re: OBD1 or OBD2 distributor? (98JDM_Type_R)
obd2 will plug right in. you can use the obd1 but it will have to be wired different
Old Aug 16, 2004 | 09:34 AM
B18A1-ED6's Avatar
run a OBD-2 dizzy and OBD-2 ecu and u should be good to go
Old Aug 16, 2004 | 09:58 AM
Sliced Beard's Avatar
Default Re: (B18A1-ED6)
seeing that you live in Cali. you cannot go down in OBD legally
what year is your car and I will help you
Old Aug 16, 2004 | 11:02 AM
Default Re: (dirtyd463)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dirtyd463 &raquo;</TD></TR><TR><TD CLASS="quote">seeing that you live in Cali. you cannot go down in OBD legally
what year is your car and I will help you</TD></TR></TABLE>
00 Civic CX
Old Aug 16, 2004 | 11:21 AM
Default Re: (98JDM_Type_R)
you will need to use an obd2 dizzy and an obd2b ecu (97+ GSR ECU)
Old Aug 16, 2004 | 12:18 PM
I have an obd1 ecu. Do I still need to use a OBD2 distributor.
Old Aug 16, 2004 | 12:19 PM
As for the legal aspect, I really don't mind. I'm going to turbo the motor.
Old Aug 16, 2004 | 08:16 PM
ttt
Old Aug 19, 2004 | 01:00 PM
ttt
Old Aug 19, 2004 | 01:51 PM
well you will need an obd2 dizzy because of the engine harness you are using unless you want to rewire stuff in order to use an OBD1 dizzy which would be more work
and a conversion harness for the ECU
it will have to be an OBD2b to OBD1 conversion harness in order to use the OBD1 ecu
diviznrider
13
Apr 19, 2019 01:38 PM
civic-one
Jul 30, 2009 06:00 AM
98JDM_Type_R
Aug 19, 2004 04:32 PM
inline4
15
Sep 9, 2003 03:03 PM
