ecu chip removal?
Old Dec 9, 2006 | 03:48 PM
b18bcrxhf's Avatar
Default ecu chip removal?
if i take the aftermarket chip out of my p28 will it return to the stock fuel maps? it has a zif socket so it will pop right out. im swapping the motor right now and im going boost so i dont want a NA chip advancing my timing
Old Dec 9, 2006 | 04:40 PM
IN VTEC's Avatar
Default Re: ecu chip removal? (b18bcrxhf)
Cut the J1 jumper next to the 28-pin external ROM socket, or you can just recalibrate the ECU to be boost friendly.
Old Dec 9, 2006 | 07:11 PM
Relic1's Avatar
like IN VTEC said. If you cut or remove J1 it will return to the stock maps.
The chip (if it runs well) can simply have boost added to it fairly easily. That is if the chip is eraseable.
The N/A portions of the map will be identical to what you have now, but the boost portions will pull timing and add fuel.
Old Dec 9, 2006 | 07:25 PM
b18bcrxhf's Avatar
thanks for the info! im going to burn a chip for it eventually and put some 450's in it but for right now i just need it to run semi safe
2.0 civic
Jan 9, 2010 08:56 AM
honda_coupe
Jun 11, 2006 01:20 PM
ThePest
Aug 9, 2005 08:43 PM
Hybrid
Mar 23, 2003 06:55 AM
Hybrid
Feb 13, 2002 12:22 PM
