Eagle Rods, what bearings to use?
Old Aug 5, 2002 | 05:47 PM
slooowDX's Avatar
Default Eagle Rods, what bearings to use?
i'm building a B20/VTEC for a buddy of mine. i'm using OEM main bearings, but i dont kno if i can use OEM rod bearings w/ the Eagles? any help would be appriciated
Old Aug 5, 2002 | 06:30 PM
non-VTEC's Avatar
Default Re: Eagle Rods, what bearings to use? (slooowDX)
OEM honda bearings will work good with the eagle rods!
Old Aug 5, 2002 | 07:00 PM
earl's Avatar
Stock bearings are fine but color codes no longer apply. Or you can use ACL's as they are one size fits all.
Old Aug 5, 2002 | 07:33 PM
onebadLSS's Avatar
Oem bearings work wonderfull, I have Eagle rods in my LS, but you need to be sure to get the correct bearings, I dont know about the B20, but on a B18b, the stock rods are number coded 1-4, and the crank is letter coded, you match these up to get the color code for the bearings. The eagle rods should be a honda factory rod code 3, well, at least on a B18b, call Eagle and talk to a tech to be sure.
I'm certain you'll be happy with the rods though, my setup revs to 9700 a lil more than I should with no problems to date.
Sketch_hs
Mar 1, 2006 07:07 PM
EKB18BPR3
Jul 18, 2004 05:06 PM
douglas_be
Feb 23, 2004 09:17 AM
EKweezy
Oct 8, 2003 10:09 AM
civicguy
Mar 29, 2002 04:56 AM
