d16z6 conversion issues
Old Apr 10, 2016 | 10:23 AM
jambo1's Avatar
Default d16z6 conversion issues
Hi guys I recently swapped out my d16y7 for a d16z6, I'm running the standard y7 engine loom with the injector plugs changed, 2wire IACV, dizzy jumper harness and p28 ecu with jumper harness, now to the problem.
I fitted a new battery last week in preparation to start the engine, switch ignition on (dash lights on, imo light on for 2secs then off) but no crank, checked the starter and have 12v at main wire, this is where it gets weird I have 12v across all my engine and gearbox (checking with power probe) and also my injector plug pins have 12v showing at each side even when unplugged (with power probe again) if I disconnect the small earth lead form the power steering pump to the earth point at o/s headlight area I get 12v at the engine side and earth across the chassis, if I earth this wire with my power probe the engine all goes back to negative and the starter clicks when on crank but the immoboliser light flashes
Any ideas guys, thanks
Old Apr 13, 2016 | 12:46 PM
jamescallowa's Avatar
Default Re: d16z6 conversion issues
My buddy did the same swap. I will ask him and get back to you. His Civic is running great with D16Z6 !
Old Apr 14, 2016 | 02:02 AM
jambo1's Avatar
Hi bud thanks but I manage to find the problem last night, main earth strap from gearbox to chassis leg at o/s was corroded badly and couldn't see due to the insulation, ran a new earth lead and started first time 😃 Can start my turbo setup now
bk201
K Series
Oct 3, 2017 03:39 AM
Alex_S
Jul 27, 2014 03:20 PM
adamf0707
10
Dec 7, 2012 03:51 PM
fabe85
Nov 12, 2006 07:24 PM
89dxhunchback
May 31, 2003 11:09 AM
