HELP PLZ, CAR WON't Start!!! PLZ help FUSTRATED
Ok Iam getting a check engine light. Iam trying to jump service connector (yes i have done this beforfe to my previous integras), but no-luck it acts the same way.
check engine light just stays on. also the SRS stays on.
Car used to run fine. (new dizzy, plugs, wires)
Iam not getting power to fuel pump, only way to get power is manualy running a 12v power to the grn/yellow wire at fuel pump.
engine just cranks and cranks.
How do i verifiy power to ECU
Also i have no ignition switch (was cut out by theifvin local proformance shop)
Iam just touching together all teh wire on the ignition harness to teh starter wire, to get it to crank.
i already swapped out for another realy and same problem.
Do you think its main relay.
Cogent Argument Enthusiast
Re: HELP PLZ, CAR WON't Start!!! PLZ help FUSTRATED (fabe85)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fabe85 »</TD></TR><TR><TD CLASS="quote">
Huh? Which relay did you replace? If it wasnt the main, then your situation sounds liek the classic main relay. I had BOTH my civic and integras main relay **** on me at the same exact time, I was pissed
TrueNorthStar
Audio / Security / Video
13
12-03-2003 01:35 PM
