Running no thermostat???
Old Aug 9, 2002 | 09:03 AM
DR. ON POINT's Avatar
Banned
Default Running no thermostat???
Any benefit to doing this except cooler temperatures.....what can go wrong and why??
whats everyones thaughts?
Old Aug 9, 2002 | 09:08 AM
DSF's Avatar
DSF
Default Re: Running no thermostat??? (On Point EK!!!!!!!!)
At idle, there's a chance of overheating. The coolant moves through the radiator fast enough that it doesn't have a chance to lose it's heat. Seen it happen before.
Old Aug 9, 2002 | 09:21 AM
dust's Avatar
Default Re: Running no thermostat??? (DSF)
Not to mention the fact the coolant moves throught the engine so fast it doesn't have a chance to absorb the heat. Your temp gauge reads the temp of the coolant so everything looks good, nice low temp gauge. But if the coolant isn't removing the temp from the engine like it's supposed to, where's that heat really going?????
Run the thermostat!
Old Aug 11, 2002 | 07:22 PM
ion_four's Avatar
Default Re: Running no thermostat??? (dust)
you can run a restrictor plate in its place. just have a piece of metal in there with a hole the size of the thermostat opening and you have a 0º thermostat! as cool as this is, I don't think it's necessary. you probably need to find some other cooling solution...try a lower temp thermostat AND a thermoswitch for the fan.
Old Aug 11, 2002 | 07:32 PM
1.8EG-T's Avatar
Default Re: Running no thermostat??? (ion_four)
Or you could run the thermostat...after drilling holes in it, that way there still is some sort of blockage to slow the coolant down.
Old Aug 11, 2002 | 07:42 PM
rjardy's Avatar
Default Re: Running no thermostat??? (hybridrex)
It allso makes the warm up in the morning take forever.....
Rob
bikewithnoname
15
Apr 2, 2009 11:34 AM
bow tie
Jun 25, 2008 02:38 PM
brokenojoke
14
Jan 14, 2008 07:37 PM
superstud
Oct 14, 2004 12:44 PM
dkdjlf
Aug 14, 2003 10:34 AM
