Compression and octane question
Old Jul 6, 2001 | 04:57 PM
Austin's Avatar
Default Compression and octane question
A friend of mine has a gsr engine with CTR pistons and CTR cams...he also has the Venom nitrous kit, installed but not to be used until he has car tuned with Hondata...
Question:
What octane does this setup warrant? I am pretty sure that with the CTR pistons in the gsr block he should have a 12.3/1 Compression ratio.
Thank you,
Austin
Old Jul 8, 2001 | 09:09 PM
Austin's Avatar
Default Re: Compression and octane question (00itr0757)
Anyone?
Old Jul 8, 2001 | 09:19 PM
accordking's Avatar
How much N20 are we talking about?
Old Jul 9, 2001 | 09:13 AM
VTEC4GS's Avatar
This setup can run with 93/94 octane fuel and would not ping provided you use at least 6 heat range plugs and dont buy fuel from Uncle Ben around the corner.
greg
Old Jul 9, 2001 | 09:21 AM
Austin's Avatar
Default Re: Compression and octane question (vtec4gs)
greg
Thanks...haven't been able to get a solid answer anywhere, he decided to run leaded 118 until he has the car properly tuned...he just burnt through his first O2 sensor last week.
Austin
Old Jul 10, 2001 | 08:28 AM
Maxi's Avatar
I'm running 12.4:1 compression and the engine runs just fine with 94 octane up here in Canada.
FastFoot
May 19, 2014 08:42 AM
BryanEk
26
Apr 1, 2005 12:23 PM
shreddinryguy
May 7, 2004 10:00 PM
Cow
Nov 6, 2002 05:40 PM
SpeedMonkeyRacing
Aug 4, 2002 08:44 PM
