Compression is killing me!
I thought I knew something about compression and engines but now I'm pulling my hair out.
#1/265
#2/190
#3/170
#4/185
B16A all stock
what would cause #1 to be so much higher than the rest? someone please school me on this!!!
BTW: I was driving about 65 down the interstate when the engine just shut off and I blew the FI E/M fuse under the hood.
now I can not start the motor at all (after replacing the fuse)
It will turn over but will not start until I go to WOT then it starts but back fires like a mother ****** then dies as soon as I let off the gas pedal.
NOTE: I have spark, fuel pressure and some compression(look at the numbers above). measured the resistents on all injectors(in spec), changed out ecu(still nothing)....all sensors(map, tps, iat, coolant) all have spec readings.
please help me I am lost!!!!!!!!!!!!
#1/265
#2/190
#3/170
#4/185
B16A all stock
A stock B16a shouldn't have 265 PSI...that's a bit overzealous, there
Check your clearances, check to see if any oil/coolant is being burned or mixed, and then do a leakdown test to see where you are losing your compression.
Turbo-charged
Mar 24, 2008 07:53 AM
severe97
16
Nov 6, 2007 05:34 PM
