compression test
Old Jun 17, 2004 | 03:26 PM
17GSR17's Avatar
Default compression test
can anyone tell me how to do a compression test or does it have to taken to a shop. i've searched but found no clear answer
Old Jun 17, 2004 | 03:28 PM
RevenantAE's Avatar
Default Re: compression test (17GSR17)
1: Buy compression tester from local auto parts store
2: With a cool car, remove your spark plugs and the fuse for your fuel injection
3: Thread compression testter into a spark plug well
4: turn over the car for about 10 seconds
5: Look at the guage, write down the pressure and the cylinder number
6: Repeat for other cylinders
7: Check that numbers are within spec for your engine
8: Check that all cylinders are within 10% or so of one another.
Old Jun 17, 2004 | 03:44 PM
J337_UNIT's Avatar
Default Re: compression test (RevenantAE)
compression testers are cheap ... under 30 bucks from sears
BTW do it when your car is warmed up because this way everything (seals, piston rings) is expanded.
The fuse you gotta pull is the 15A ECU/FI fuse from the fuse box underneath the hood.. its a small one..
make sure you do it with a wide open throttle plate.. step on the gas pedal all the way when cranking..
Old Jun 17, 2004 | 04:06 PM
17GSR17's Avatar
thank u very much. I asked before and someone was a smartass about it. appreciate it
Old Jun 17, 2004 | 05:21 PM
milo's Avatar
http://www.c-speedracing.com/h...t.php
Old Jun 19, 2004 | 08:14 AM
BDBGoalie1982's Avatar
Default Re: compression test (milo)
I just checked mine, and got
260, 255, 250, 260
Perfectly within specs. Is that good variance for a 15k mile motor?
CTR pistons, bored 10 over, race port, valve job, ect. I'm told that should result in about 12.05:1.
Anyone know how to convert the psi readings to a ratio?
Thanks
H2b-eghatch
Nov 8, 2016 04:44 PM
JDM EJ1 95
Sep 8, 2004 09:15 AM
Traction
Apr 6, 2004 06:11 PM
wm5holla
Mar 23, 2003 03:39 PM
WICKED2
Jan 21, 2002 12:43 AM
