Code 20 ELD Electronic Load Detector only @ high RPMs Need Help
Old Oct 15, 2008 | 02:20 PM
SinglecamMitch's Avatar
Default Code 20 ELD Electronic Load Detector only @ high RPMs Need Help
Car: 1993 Honda Civic Dx from Canada
Motor: D16z6 P29 Build 12:1 Compression Tuned on crome
Problem: From a second gear pull reving to 7300 Rpms then shifting into third it will be fine pull for a little then at 6200 it will pop up the a CEL code 20 and disable v-tec. We have replaced the fusebox twice, altinator twice and swapped batterys... The ELD is disabled in crome and we have tried mutiple burns of the chip.. If anybody has any advice or solution to the problem please help thanks
Old Oct 15, 2008 | 07:07 PM
Default Re: Code 20 ELD Electronic Load Detector only @ high RPMs Need Help (SinglecamMitch)
Bump Nobody knows?
Old Oct 16, 2008 | 07:09 AM
bump need some help
Old Oct 16, 2008 | 12:19 PM
HitF8's Avatar
Default Re: (SinglecamMitch)
bump
Old Oct 16, 2008 | 01:54 PM
Egezzy's Avatar
Spongebrad Squarepants
Default Re: (HitF8)
uve changed load devices. .but have the checked the wiring??
Old Oct 16, 2008 | 04:37 PM
Default Re: (HitF8) (Egezzy)
it couldn't be wiring because it only throws the code 20 at high rpms in third at 6400*
Old Oct 17, 2008 | 04:13 AM
Egezzy's Avatar
Default Re: (HitF8) (SinglecamMitch)
voltage drop test would work. .i mean technically y would it be the battery at that hi of an rpm cuz it.s basically a voltage stabilizer at that point. .i mean a ground could be loose. .nething. .jus weird it doesnt do it when u rev thru second but does it at a lower rpm n 3rd.
Old Oct 18, 2008 | 09:43 AM
how do i perform a voltage drop test? and all the grounds seem fine but ill tripple check and resurface em
Old Oct 18, 2008 | 07:32 PM
Egezzy's Avatar
run ur positve lead on ur voltmeter to the batt+ n ur negative lead to the load device. .u will then get a reading. .then test afta the load device to make sure the device is taking all available power.
Old Oct 19, 2008 | 11:44 AM
oh you mean under the fuse box... Ive done those tests and they all came back within spec... is there some way i can perform this test while driving? to see if something happens
Old Oct 19, 2008 | 05:13 PM
Egezzy's Avatar
no no it.s diff as n load devices (ie. ur alternator). .n i spaces this was happening at higher speeds n rpms. .i think it.s due to the vibration. .u need to shake some **** n ur bay n see if u can find sompthin loose. .fuuuck i hate tryin to help ova a forum. .lol. .i wish u lived down the street. .lol.
Old Oct 23, 2008 | 06:58 AM
i understand what your saying and ill check to see if there is nething noticable could it maybe be a loose wire pin in a clip or something going to the alt?
Old Oct 29, 2008 | 10:37 PM
could this be a bad bin on the chip and maybe it just needs to be made into a new file with the same map? I was told it could be the file please let me know
Old Dec 15, 2008 | 05:57 PM
slowturbocx's Avatar
did anybody help this man? i have the same freaking problem.
disables vtec and eld code comes up.
1992 hatchback with a b16 swap
91efalex
Jul 19, 2010 05:19 PM
92HBack
Aug 30, 2009 03:32 PM
2poor2tune
14
Nov 16, 2006 06:21 PM
Bright Eyes
Jun 3, 2005 05:52 PM
Escabar
Oct 29, 2003 08:37 PM
