Code 21
Old Jun 15, 2009 | 09:53 AM
92HBack's Avatar
New User
Default Code 21
1995 D16Z6 just swapped in. I fixed a code 22.
Now when I get into vtec rpm range I get code 21. Once I turn off the car and back on its gone. All connectors are getting proper voltage/ohms. Oil is new and full. Any ideas?
Old Jun 15, 2009 | 03:35 PM
KWayRacing's Avatar
Default Re: Code 21
What ecu are you running?
Old Jun 17, 2009 | 11:17 AM
92HBack's Avatar
New User
Default Re: Code 21
P28
Old Jun 18, 2009 | 10:07 AM
G MoNeY Ej1's Avatar
Default Re: Code 21
bump cuz i got the same problem
Old Jun 19, 2009 | 07:53 AM
92HBack's Avatar
New User
Default Re: Code 21
I'm guessing my redneck wiring job is to fault...
Once I have my stage colder plugs to stop my pinging problem, I'll solder my wires to the solenoid and see what that does.
G Money, When we get code 21 only when its in vtec range, and its resetting when the car is off it is supposedly an intermittent problem. So check your connections, and oil level/condition and see if you can find something there. Let me know if you figure it out! O and clean the solenoid screen too.
Old Aug 30, 2009 | 03:32 PM
crowmagnum's Avatar
Default Re: Code 21
bump, im having the same problem, but my CEL is on all the time
1kleenef
Jan 23, 2009 01:19 PM
wrxya33
Jul 6, 2007 08:16 AM
Mach69
Jul 19, 2005 11:47 AM
bpo
May 31, 2005 06:31 AM
SOHC_MShue
16
Apr 30, 2005 12:58 PM
