Code 15! Please help me out guys
Old Jun 8, 2003 | 07:15 AM
Patch's Avatar
Default Code 15! Please help me out guys
I've been getting no spark since last Monday. I replaced the igniter, coil, rotor, cap, plugs, and plug wires. It still would not fire. Yesterday I bypassed the ignition switch, and ran a wire from the battery to a toggle switch to the + side of the ignition coil. The car finally started, and I got it home. But I'm still throwing code 15. What could possibly be causing this? The only thing I can think of is the wiring between the ECU and the distributor. Does anyone know? I'm desperate, please help me.
Old Jun 8, 2003 | 09:16 AM
3gdude's Avatar
Default Re: Code 15! Please help me out guys (CRX PAT)
Sounds like a bad ignition switch (electrical portion). Try resetting ECU, then flip your toggle switch to power up coil, then start car and see if code re-sets. In that exact order.
Old Jun 8, 2003 | 10:48 AM
Patch's Avatar
Default Re: Code 15! Please help me out guys (3gdude)
I just tried that, and it worked. When I left my friends house, I went to ON first, then flipped the switch and I threw code 15. I'll just have to remember the order. Thanks.
Old Jun 8, 2003 | 03:39 PM
af97civic's Avatar
how exactly do you check the engine codes.thanks for the info
Old Jun 8, 2003 | 04:14 PM
3gdude's Avatar
Good, glad that helped you. Ignition switches from Honda are pretty reasonable in price and are real easy to install. I just bought one for my daughters 97 Accord and it was like 30 dollars my cost. Nice diagnostic work on your part made this an easy fix....3gdude
i hate import cars
Oct 21, 2008 12:34 AM
abelacha
Jun 10, 2007 09:06 AM
4b1z
Feb 25, 2005 12:45 PM
EGJDM
Feb 5, 2005 12:27 PM
st0nedstoopid
Nov 5, 2003 02:13 PM
