What does ecu code 15 Ignition output signal mean
Old 02-04-2004, 12:29 PM
EGJDM's Avatar
Default What does ecu code 15 Ignition output signal mean
I just read the code from the ecu and it is returning code 15 Ignition output signal. Does this mean a problem with the distributor? or what really need your guys help I need to get my car running`!!!!!!!!!
JDMlyfestyle's Avatar
I believe that would be referring to the coil
Old 02-04-2004, 12:32 PM
EGJDM's Avatar
Default Re: (JDMlifestyle)
Can the coil be replaced or what?
Old 02-04-2004, 12:39 PM
nd8ch's Avatar
Default Re: (EGJDM)
i had that when the plugs on the ECM were loose and the car started to run really bad (tach jumping and car stalling), i clamped the plugs smaller so they fit on the ECM terminals better
everythig was fine after that. hope this helps
Old 02-04-2004, 12:50 PM
EGJDM's Avatar
Default Re: (nd8ch)
Thanks I will try that!!!!!
Old 02-05-2005, 12:25 PM
wompwomp61's Avatar
Default Re: (EGJDM)
whats an ECM??
Old 02-05-2005, 12:27 PM
Luserkid's Avatar
Default Re: (wompwomp61)
When i had that code my Ignitor went out.
dhernandez_9117
10-13-2009 06:29 AM
90crvtec
08-19-2005 07:19 PM
kuteboi
01-29-2005 09:11 PM
CiViC SiR
07-04-2003 02:24 PM
Quick Reply: What does ecu code 15 Ignition output signal mean
