Playing with cam timing requires resetting ignition timing??
Old Jun 17, 2007 | 11:09 PM
Mugen_DC2R's Avatar
Default Playing with cam timing requires resetting ignition timing??
would Playing with cam timing requires resetting ignition timing??
i read this from https://honda-tech.com/zerothread?id=1001416
is this true??
thx
Old Jun 18, 2007 | 05:38 AM
Padawan's Avatar
Darth ModerVader
Default Re: Playing with cam timing requires resetting ignition timing?? (Mugen_DC2R)
If you adjust the intake cam timing on a DOHC engine, you also alter the base ignition timing. The same is true if you adjust the cam timing on an SOHC.
Old Jun 18, 2007 | 06:47 AM
Mugen_DC2R's Avatar
Default Re: Playing with cam timing requires resetting ignition timing?? (Padawan)
that means, if i only adjust the exhaust side, i don't have to make changes to the ignition timing?
Old Jun 18, 2007 | 07:20 AM
EE_Chris's Avatar
The intake cam is what drives the distributor, not the exhaust. If you adjust only the exhaust cam, you haven't effected ignition timing.
Old Jun 18, 2007 | 08:04 AM
Mugen_DC2R's Avatar
Default Re: Playing with cam timing requires resetting ignition timing?? (EE_Chris)
ok thx
Treyschls
Apr 13, 2023 07:04 AM
kirkland08
Feb 13, 2011 08:59 AM
has-t
Jul 1, 2003 09:58 AM
redcxhatch
Nov 16, 2002 08:04 AM
N1Spec
Nov 18, 2001 11:15 PM
