timing???
Old Mar 11, 2004 | 07:35 AM
donnjuan2point2's Avatar
Default timing???
i have searched this and found no answer. my skunk 2 cam gears say 1 mark = 2 degree crank, does this mean that 1 mark = 2 degrees in reference to cam timing, also by advancing the cam timing is that also advancing ignition timing. sorry if ur tired of this topic but any answers are appreciated!
Old Mar 11, 2004 | 10:49 AM
SOHC_MShue's Avatar
Default Re: timing??? (donnjuan2point2)
i am not positive, but I think it means that 1 degree cam timing = 2 degree crank like you said. Also if you advance your ignition timing you are advancing ignition timing and will have to reset ignition timing back every time you adjust your cams.
Treyschls
Apr 13, 2023 07:04 AM
kirkland08
Feb 13, 2011 08:59 AM
EX-T
Jan 21, 2009 04:16 PM
johnwohl
Apr 1, 2008 07:29 PM
redcxhatch
Nov 16, 2002 08:04 AM
