B16a2 low power ..help please
Old Apr 12, 2016 | 06:47 AM
bedd_v07's Avatar
Default B16a2 low power ..help please
I think slow acceleration
What is my cars problem?
0-100: 10 seconds. 0-160 :30 seconds
Dc 4-2-1 headers, 61 mm ,
P28 ecu
Non-cat
Hks air filter
4.4 final drive transmission
Vtec solenoid is clean , and distributor is new
Thanks for all helps..
https://youtu.be/yDQWbRFf0aE
Old Apr 12, 2016 | 07:24 AM
e0325's Avatar
Default Re: B16a2 low power ..help please
is the ecu chipped or the b16?
Old Apr 12, 2016 | 10:34 AM
bedd_v07's Avatar
Chipped, but my think is not professional chipping,my place dont have knowledge persons,
Can ı find prepared tune on internet?
Old Apr 12, 2016 | 10:44 AM
e0325's Avatar
Pherable has chipped ecu or you send them yours to chip.
Engine Parts & Tuning Solutions | Phearable.net
what kind of civic is this?
a stock P2T ecu would also work.
Check your timing, if its a tooth off you could have power loss
Old Apr 12, 2016 | 11:42 AM
2kdrift's Avatar
"chips" are not the same as a tune. It really depends on what was written to the chip and if its based on your particular setup. The chips you find online are very generic and NOT BASED ON YOUR PARTICULAR ENGINE.
is this a gsr or ls transmission?
I would start with the basics, mechanical timing, dizzy timming, spark plugs, check compression
Old Apr 13, 2016 | 09:25 AM
bedd_v07's Avatar
Transmission is s80 4.4 final drive,
Sorry, ı dont great english , ı understand You say me "you must find the professional chipper "
Old Apr 13, 2016 | 04:19 PM
flesh199's Avatar
Try the stock ecu first to see if you have any problem.
Old Apr 13, 2016 | 05:46 PM
bedd_v07's Avatar
Which ecu is orginal for b16a2
160 hp ek 1998
Old Apr 13, 2016 | 07:05 PM
motoxxxman's Avatar
are your speed numbers in mph or kph?
if they are in mph, thats actually really fast for your setup
Old Apr 13, 2016 | 08:04 PM
bedd_v07's Avatar
Not mph , This kmh
Lasky
13
Oct 31, 2007 10:19 PM
tigueremalo
Oct 9, 2007 08:18 PM
egcivicb16
May 7, 2006 06:52 PM
alphabeatsco2004
Aug 22, 2005 06:09 PM
