automatic obd2 to manual obd1 harness probs
Old Dec 8, 2003 | 03:49 PM
witeboi's Avatar
Default automatic obd2 to manual obd1 harness probs
ok i had a d16y7 w/automatik trans and got a obd1 b16a i got the adapter for the ecu and everything if i remember correctly its a p30 ecu came with the motor supposedl and the harness i had before was non-vtec so i also need to alter those wires... basically what i am looking for is wiring diagrams and plug info what needs to be switched what i can cut... and also if i can pull the automatik brain box out w/out having to rewire the whole car...... i really need help with this if anyone can .. thanx ahead..
-lat3s
Old Dec 8, 2003 | 03:58 PM
Kendall's Avatar
Default Re: automatic obd2 to manual obd1 harness probs (witeboi)
The OBD-2 harness is for running an OBD-2 engine on and OBD-1 ECU, like running a US market B18C5 on a P28, you don't need it if you are running an OBD-1 engine on an OBD-1 ECU. Also, you will have to do some wiring work to connect the VTEC, do a search and you should find more than enough info.
Also, welcome to Honda-Tech.
Old Dec 8, 2003 | 05:25 PM
witeboi's Avatar
Default Re: automatic obd2 to manual obd1 harness probs (dc231)
thanx fer the welcum the car is already wired... and runs... but the wire work is a shitty job i am trying to clean it up i need the diagrams with pin numbers fro the ecu and i would like to know if i can strip the automatic brainbox out ...... i know what needs to be done i just need to redo it in the harness not with external wires like the place i had do it did.....
Old Dec 8, 2003 | 08:45 PM
PHiZ's Avatar
http://www.hondaswap.com/swap/viewer.php?id=58
-PHiZ
jdmshawn95
Jan 14, 2011 11:12 AM
screen_name
Apr 22, 2006 06:56 PM
quaker
Mar 10, 2004 07:25 PM
Type RS
Nov 18, 2002 10:09 PM
