Auto obd2b d16y8 engine harness on obd2a b16a2
Old Oct 7, 2016 | 03:37 PM
Slammerdc2's Avatar
Default Auto obd2b d16y8 engine harness on obd2a b16a2
hey fellow Honda enthusiasts, hopefully someone can help me out with some answers to some wiring confusion I am having with my b16 swap into a 99 Acura el (obd2b ) car . When I had bought the car , it had no motor or wiring harness..I ended up getting an automatic obd2b d16y8 harness from a 2000 el hoping it would work for the b16, the engine is a b16a2 from a 96 delsol vtec (obd2a) it came with the full swap minus shift linkage so I have the engine harness for the b16 obd2a, it's much smaller ,less plugs, and different plugs for some of the sensors I plugged in the injectors alternator , they plugged in perfect but the crank sensors seem different and a few other plugs . Now, for the ecu I have the p30 delsol ecu I was thinking of getting a b16a2 99-00 ecu to run on the obd2b auto engine harness. I'm still quite a bit of a noob with wiring so hoping for some help. Thanks very much
HotrodHooptie
Jan 6, 2018 02:59 AM
justinmaccc
Oct 18, 2015 11:10 AM
drummerdude
Aug 13, 2010 09:51 AM
Trends368
Nov 16, 2009 02:02 PM
Christian_D
Sep 26, 2008 06:31 PM
