Oil pressure gauge install?
Old Dec 29, 2007 | 07:43 PM
EFsideways's Avatar
Default Oil pressure gauge install?
Where do you tap into to install a mechanical oil pressure gauge?
Old Dec 30, 2007 | 06:18 PM
Crazydave's Avatar
Default Re: Oil pressure gauge install? (EFsideways)
The back of the block there is a stock low oil pressure swithch. Most people use this as an oil pressure sender location:
2 things to be careful of..
1.) the stock sender is a BSPT thread... you will need an adapter. Summit racing sells the apapter necessary (BSPT - > NPT)
2.) DON"T install an electric oil pressure send onto the block.
Make sure you search how to install a sender..... this has been covered tons of times.
Old Dec 31, 2007 | 08:50 AM
EFsideways's Avatar
Default Re: Oil pressure gauge install? (Crazydave)
Thanks man.Ill look into it.
Old Jan 1, 2008 | 08:10 AM
rmcdaniels's Avatar
I got a Greddy oil filter sandwich plate at a local shop, I have my VTEC oil feed and my oil line to my oil pressure sender plumbed in to it:
http://www.phantasmusa.com/oilblad.html
Old Jan 1, 2008 | 09:09 AM
EFsideways's Avatar
Default Re: Oil pressure gauge install? (rmcdaniels)
Thats going to look nice,I think ill go that route.
Old Jan 1, 2008 | 01:52 PM
Crazydave's Avatar
I have my oil pressure and temp sender on a 4-head remote oil filter head. Makes it real easy and you can keep the stock oil pressure switch in for the idiot light
twentyhurtz
Dec 7, 2008 09:17 AM
torqueless
Apr 19, 2007 03:29 AM
standbackimapro
Apr 30, 2006 07:22 PM
themorphious
Mar 21, 2006 12:16 PM
krshultz
Mar 22, 2002 02:41 PM
