BOv not activating
Old Sep 21, 2004 | 12:56 PM
StreetGlwLude's Avatar
Default BOv not activating
Just put on my turbo kit today crank it up and the blow off valve doesn't seem to be working I have an h23 si non-vtec where should I run the vacuum source? kinda makes me nervous I don't have a boost guage installed yet and I'm not sure if my wastegate is working either.
Old Sep 21, 2004 | 01:15 PM
Default Re: BOv not activating (StreetGlwLude)
it's a blitz supersound but It's not working.
Old Sep 21, 2004 | 01:31 PM
99_SH's Avatar
Maybe the batteries are dead. If I recall, it uses 1 AAA battery.
OK, now that HT has kept its as$hole reputation, i'll try to help. Make sure you have a good vacuum source. Most people 'T' a connection from their FPR. Or you can route a new line straight from the manifold!
Old Sep 21, 2004 | 01:34 PM
lol no seriously need some help.
Old Sep 22, 2004 | 05:41 AM
Anyone out there have any ideas on this?
Old Sep 22, 2004 | 06:25 AM
Kal's Avatar
Kal
get a boost gauge.
Old Sep 22, 2004 | 06:33 AM
GaRn's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StreetGlwLude &raquo;</TD></TR><TR><TD CLASS="quote">Just put on my turbo kit today crank it up and the blow off valve doesn't seem to be working I have an h23 si non-vtec where should I run the vacuum source? kinda makes me nervous I don't have a boost guage installed yet and I'm not sure if my wastegate is working either.</TD></TR></TABLE>
what is your turbo setup? do you think you could keep in touch with me about the reliability?
AIM:GaRnXe
I'm in between classes now but later today I'll see if I can find a diagram..
Old Sep 22, 2004 | 06:56 AM
fastlude69's Avatar
you want to grab a vacuum from one of the lines that use to go to your intake and run that to your bov. then you use another line to your wastegate from you im or tb
Old Sep 22, 2004 | 07:15 AM
Default Re: (fastlude69)
Garn I can keep in touch with you about the reliability etc.. It's set up to run between 5-7 psi which is all I want to run until I rebuild the block etc...
fastlude69 I've tried running a vaccum hose to just about every vaccuum fitting on the intake manifold, and it isn't working I"ve loosened it all the way up I don't even hear the bov leaking when I'm giving it gas... the wastegate I ran that to a fitting on the turbo the side where the air goes in will the wastegate work there? I was reading where it will more accurately control the boost if you hook the wastegate to the turbo.
Old Sep 22, 2004 | 07:43 AM
LudEcrous's Avatar
Default Re: (StreetGlwLude)
did you actually drive the car around and not hear it or did you try to rev it at idle? From my experience, my blow off valve will not release if i am at idle....my engine has to have load on it in order for it to go off.
Old Sep 22, 2004 | 07:55 AM
Default Re: (LudEcrous)
Hey lude that might be what's going on I didn't try driving it around I wanted to make sure everything was running before driving that car maybe that's it I'll take it off the jackstands later today or later this week and give it a try if this works I'll let you know and I appreciate the reply....I guess I just figured the BOV would work at IDLE I know I thought I was hearing compressor surge or something like that but maybe it's just cause I was at idle...just figured it should work thanks, I'll give it a try.
Old Sep 22, 2004 | 09:04 AM
Hey could it be that I have the blow off valve facing the passengers side...I read somewhere that the BOV has to be facing towards the drivers side in order to work anyone know if this is true or not? And why is it like this
phantomsi3
Aug 30, 2008 12:03 AM
Jupe
Jul 13, 2007 08:34 PM
turbod16y7
19
Jan 16, 2006 01:13 AM
jdm-ray
May 15, 2005 09:37 PM
NeXtLeVeL_TyPe_R
May 15, 2002 11:45 AM
