Clocked Turbo, Now Shaft Play?!?
I have a Precision SC34 that is practically brand new. Before clocknig the turbo, there was no shaft play. I loosen all the botls on the compressor housing all the way out and was about to clock it then remembred reading on HT froms oem guy saying not to fully remove the botls only to slightly loosen because doing so may cause play from the blades. So I put the botls back on with the plates and tightened them figner tight on all. then clocked the compressor in the way I wanted to. snugged up the bolts and now there is some side to side play!!! When spinning it and pushing it to make the side play happen, I can make it so that it rubs on the sidewall and I can feel it drag on it quite a bit. I put a bit of oil threw it and spun it a buncha times and there is still the same play and rubbage. I can see where it rubs when it does. I do have to put a bit of pressure to crate the play, but I do ahve to put even more pressure to make it rub. wtf happened?!?
Modified by Tchleung at 10:12 PM 9/18/2004
I tried that :'( I tightened them like hell almsot to the ponit of stripping and still no good. I'm gonig to loosen them all agian and rotate it some more and retighten and see if that fixes anything. this sux hell sicen this costed me a pretty penny and find out I may have wrcked it. i'll try it tomrorow and let you guys know
Damm Tommy sorry to hear that. Yes I have clocked that turbo before, but I always just loosen them to the point where I can clock the turbo. I've never taken the bolts out all the way...
Maybe it just needs to be rebalanced or something... Call Precision, and ask them what you should do.
Hoosier Daddy
Apr 14, 2004 03:51 PM
