shaft play
Old Apr 13, 2006 | 04:08 AM
brad98_teg's Avatar
Default shaft play
After running my turbo for a while I noticed I had a leak on my oil feed line. I took my turbo off and started inspecting it to make sure everything is ok. While checking the shaft I felt no movement back and forth, but if I applied a fair amout of pressure side to side it would slightly rub on the side. Im not sure if this is normal so I just wanted to make sure it was alright
thanks
Old Apr 13, 2006 | 07:26 AM
turbotime's Avatar
although some shaft play is normal in non-bb turbos, if it was full of oil then there should not be much play.
Additionally there should NEVER be anough play for the fins to contact the housing
Old Apr 13, 2006 | 07:32 AM
brad98_teg's Avatar
well since on my turbo there is enough play to rub the side with a certain amount of pressure, what could be the problem?
Old Apr 13, 2006 | 07:40 AM
turbotime's Avatar
seals are toast, needs a rebuild
Old Apr 13, 2006 | 08:03 AM
brad98_teg's Avatar
Default Re: (turbotime)
any recommendations on where I should get the new seals? Websites?
Old Apr 13, 2006 | 08:17 AM
turbotime's Avatar
ive never rebuilt a turbo- and it might not be the seals, but if u see oil leakin then its almost 100% the seals.
Im pretty sure u need to buy a rebuild kit or send teh turbo off somewhere to get rebuilt. Its not just simple seals its pretty technical, clearances, balancing the wheels, etc.
umair
Nov 16, 2013 05:42 PM
HamiltonRex
Jan 24, 2010 09:48 AM
turbotime
Mar 30, 2006 02:07 PM
1FastCoupe
Jan 27, 2006 07:07 PM
jdmcivic1999
Feb 12, 2005 04:05 PM
