Just got my brand new turbo...TINY bit of shaft play...
Is this normal? I just got my brand new Garrett t3/to4e in the mail and there's a TINY bit of shaftplay. ?
Re: (Hoosier Daddy)
I have that same problem, but I bought mine with about 2000miles on it... they said that it didn't have any shaft play/wobble, but when I tried it... it has a little tiny bit, and I have to put some pressure on it aswell.... thats normal???
Thanks
Same turbo Garret t3/to4e.
Thanks
Re: (QWKPHKR)
i have never seen a turbo that had absolutley ZERO shaft play. eveyr turbo i have seen had a tad bit of shaft play when moved from side to side. but no turbo should have shaft play when moved in and out
Re: (QWKPHKR)
and some turbos use a different cartridge bearing type that will have some free play due to the design, especially without oil pressure...
mike
mike
Re: (JonGP4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JonGP4 »</TD></TR><TR><TD CLASS="quote">i dun no my 4000 mile IHI turbo.. had NO shaft play at all.. on my apexi kit BB turbo</TD></TR></TABLE>
that has a lot to do with its ball bearing nature...most center cartridges are fluid-based thrust bearings.
mike
mike
1 Post
Re: (MikeMAN)
when i got my turbo brand new it didnt have shaft play at all...it was solid- but when i rotated the housing... it wobbled. is there such a thing as tq specs when thightening up the bolts?
