Do I need Boost Retard w/ only 8 to 10 psi boost??? w/ SAFC, 450cc injectors..??
Old Sep 16, 2004 | 02:34 PM
MarkAngelo's Avatar
Default Do I need Boost Retard w/ only 8 to 10 psi boost??? w/ SAFC, 450cc injectors..??
I was just wondering where people usually set their distributor timing when running boost... I have a B18a motor, OBD-1, and am about to boost it 8 to 10psi, running the SAFC w/ 450cc injectors... Do I need a BOOST RETARD MODULE??
Thanks!
Mark
Old Sep 16, 2004 | 02:41 PM
USDM 4G VTEC's Avatar
yes u need to retard some timing when boosting
at least 0.60 per/psi
Old Sep 16, 2004 | 09:55 PM
Del_Slowest's Avatar
Default Re: (USDM 4G VTEC)
http://www.ecimulti.org/uberdata
Old Sep 16, 2004 | 10:17 PM
crispydee's Avatar
Default Re: (Del_Slowest)
Can uberdata be used on a 91 UKDM vtec (B16)
Old Sep 17, 2004 | 12:08 AM
94dxt's Avatar
Default Re: (crispydee)
2-3 degrees total I'd say
Old Sep 17, 2004 | 12:34 AM
civickiller's Avatar
Default Re: (94dxt)
i would say more like 4 to 6 degrees total retarded, suppose to leave dist at stock timing and just subtract from ems, whichever one you using
Old Sep 17, 2004 | 12:59 AM
dohcnotec's Avatar
Default Re: (civickiller)
on 93 octane, you can run 6psi w/o retarding timing (with at least 12.5:1 a/f across), so... if you feel like King Longdick, go for it...
Old Sep 17, 2004 | 01:40 AM
swlabhot's Avatar
Default Re: Do I need Boost Retard w/ only 8 to 10 psi boost??? w/ SAFC, 450cc injectors..?? (MarkAngelo)
I would definitely retard the timing before you booost!! I'd do around 4-5 deg
Old Sep 17, 2004 | 08:54 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crispydee &raquo;</TD></TR><TR><TD CLASS="quote">Can uberdata be used on a 91 UKDM vtec (B16)</TD></TR></TABLE>
if it has an external rom then yes. i'm pretty sure all obd1's have external roms
Old Sep 29, 2004 | 09:49 PM
crispydee's Avatar
mines the ODB0 so i expect not.
Old Sep 30, 2004 | 05:12 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crispydee &raquo;</TD></TR><TR><TD CLASS="quote">mines the ODB0 so i expect not.</TD></TR></TABLE>
try http://www.turboedit.com for obd0 cars
1990hondaHF
Oct 26, 2010 06:36 AM
93civciv
Dec 4, 2007 05:23 PM
pipes
Feb 20, 2004 09:19 AM
X2BOARD
Jul 26, 2003 07:35 PM
willyboyK20
Oct 30, 2002 09:50 PM
