breaking in a new motor build...
k i just got my block back from benson's, gonna put in JE pistons, eagle rods, then putting a turbo on shortly after.. my question is what procedures should i do to make sure it lasts and i dont **** it up early in its life? what oils should i use and for how long, and then what should i switch to? how long should i run it for before i put the turbo kit on it? etc etc, specifics would be a great help, thanks
on my old motor, my piston rings became shot after about 50k miles. it probably wasn't broken in right, and the guy who did the build that i bought the car from probably didn't use the right oils in the beginning, not to mention it was revved up to 9500rpm atleast a dozen times a day
i just want to make sure this thing lasts more than 50k miles... what should i do/ what shouldnt i do? (not rev above 4k for the first 1000 miles?)
oil- https://honda-tech.com/zerothread?id=861226
oil and reving- https://honda-tech.com/zerothread?id=674674 5th post down is good
another good thread- https://honda-tech.com/zerothread?id=413044
search is your friend
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redturbocivic »</TD></TR><TR><TD CLASS="quote">i broke my benson block in on the dyno....for tuning reasons</TD></TR></TABLE>
Broke mine (not Benson) in on the dyno as well. Perfect 200 compression across the board.
same here
same here
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lke2drvgsr »</TD></TR><TR><TD CLASS="quote">my question is what procedures should i do to make sure it lasts and i dont **** it up early in its life? </TD></TR></TABLE>
Have it built by someone who knows what they are doing.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suprdave »</TD></TR><TR><TD CLASS="quote">
Have it built by someone who knows what they are doing.</TD></TR></TABLE>
Broke mine in on the dyno and it's doing great!
