My eg has no heat when i turn the heat on only blows cold air(heater core gone bad???
Old Sep 15, 2004 | 03:29 PM
hatchbackhonda's Avatar
Default My eg has no heat when i turn the heat on only blows cold air(heater core gone bad???
whenever i let the car warm up and turn the heat on it only blows cold air!!!!
i am thinking that the heater core went bad but i thought when a heater core goes bad it leaks coolent but i could wrong
what else could it be????
any suggestions
Old Sep 15, 2004 | 03:42 PM
Evil_Wizard's Avatar
Default Re: My eg has no heat when i turn the heat on only blows cold air(heater core gone bad??? (hatchback
sounds like the cable has come off of the valve. Check under the dash and see if the valve is moving when you move it from hot to cold. Other then that there is a valve on the inside of the firewall that can be shut off as well. Check both of those and let me know.
Old Sep 15, 2004 | 03:47 PM
EGinNY's Avatar
When you slide you Temp. control from heat to cool do you hear it switching something behind the dash...?????
It should have some tension to it when sliding...
If not could be the cable running to you climate control (common prob.)
Look underneath your Intake Manifold on the passenger side, there should be a small silver cable/wire with a bend at the end going into a hole on black plastic sliding piece......Try moving it manually under there.......(sorry for the bad description)
EDIT: beat me to it ^
Modified by EGinNY at 11:19 PM 9/15/2004
Old Sep 15, 2004 | 08:43 PM
thanks everyone for the help i will check it in the morning and get back to ya if it fixed it
to honda-tech
gixxerboy750
Jan 17, 2010 07:43 AM
Evolution-93-Ex
Jul 31, 2009 03:25 PM
navin
Dec 16, 2007 10:04 PM
TheIceMan
Feb 20, 2005 02:20 PM
type gsr
Oct 19, 2004 07:23 AM
