85mm too much for the street?
Old Sep 13, 2004 | 10:48 PM
EdBoon's Avatar
Default 85mm too much for the street?
Quick question guys....I'm planning on building my b18c1 motor...wanna go with 85mm sleeves / 11.8-12.0:1 wiseco pistons bottom end wise.
Would love to run 91 octane and be able to go full throttle at will.
How many people actually run a similar setup daily driven?
Old Sep 14, 2004 | 12:47 AM
aznsmtboy's Avatar
Default Re: 85mm too much for the street? (EdBoon)
i'm planning on going 84.5 mm with 11:5:1 compression, project is in the works, FAR from being finsihed, unfortunately
Old Sep 14, 2004 | 04:32 AM
1 2 NV's Avatar
seriously, what kinda question is this. u act like ur goin to b drivin a 572 crate motor with low compression pistons w/ a blower on methanol.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EdBoon &raquo;</TD></TR><TR><TD CLASS="quote">85mm too much for the street?</TD></TR></TABLE>
hahahahahaha
Old Sep 14, 2004 | 04:43 AM
NAstreetEH2
Guest
Posts: n/a
Default Re: 85mm too much for the street? (1 2 NV)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1 2 NV &raquo;</TD></TR><TR><TD CLASS="quote">seriously, what kinda question is this. u act like ur goin to b drivin a 572 crate motor with low compression pistons w/ a blower on methanol.
hahahahahaha </TD></TR></TABLE>
he's probally talking about reliabilities sake...
but i'm running 85 on my daily driver, aebs sleeves and 11.5:1 in current form..but i'll go back to a regular head gasket after break in and be at 12:1
Old Sep 14, 2004 | 05:39 AM
SMSP's Avatar
FYI-
I have a set of 85mm B20 pistons for sale for $150 shipped and that includes the pins and rings.
Old Sep 14, 2004 | 07:40 AM
EdBoon's Avatar
Whoa there keyboard warrior...I know ur hot **** with ur full race car bustin 11s...but I don't see a problem in gathering input about reliability issues.
Old Sep 14, 2004 | 08:26 AM
DEVIOUS_EG*'s Avatar
Default Re: 85mm too much for the street? (SMSP)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SMSP &raquo;</TD></TR><TR><TD CLASS="quote">FYI-
</TD></TR></TABLE> stock 85mm ?
Old Sep 14, 2004 | 08:33 AM
NAstreetEH2
Guest
Posts: n/a
yeha, they have overbore pistons from Honda, ya know
you can get a b20 gasket in 85mm too
Old Sep 14, 2004 | 10:35 AM
Big Teggie's Avatar
You will be good with a 85mm bore, I hear many around here run it on the street.
You can always go 85.5mm or 86mm bore down the road if you need.
Old Sep 14, 2004 | 10:47 AM
WHITFIELD-TUNED's Avatar
DYNO-PRO
From: SoCal I.E 909, CA, where we innovate not immitate
Default Re: 85mm too much for the street? (Big Teggie)
85MM BORE shouldnt cause any reliability issues, your comp ratio on 91 octane may be your downfall, it can be done however the car NEEDS to be tuned on a dyno with a wideband o2.
Old Sep 14, 2004 | 04:57 PM
EdBoon's Avatar
Default Re: 85mm too much for the street? (HOOKUPS)
I do have Hondata...so it'll definitely retuned. One thing that scares me is that I've had problems with my s100/p28. Tuning for some reason got thrown off (started running too rich)...randomly throw code 43s. I never had this problem with my old p72/stage3 setup.
I was originally told to just go with high compression with ib spec super dupers. But I want to be able to drive this car around as I do already, drive to and back from the track, etc.
Is 11.8-12:1 pushing it for us on 91? I know some reputable builders like Tech43/Omniman recommend 11.5 (correct me if I'm wrong).
Old Sep 14, 2004 | 05:40 PM
t-blizzard's Avatar
i run 11.5 arias 85 mm daily, and so far so good. have it tuned well and you shall have no problems, oh and have a reputable builder do the work.
Old Sep 14, 2004 | 06:30 PM
EdBoon's Avatar
Default Re: 85mm too much for the street? (t.blizzard)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by t.blizzard &raquo;</TD></TR><TR><TD CLASS="quote"> oh and have a reputable builder do the work.</TD></TR></TABLE>
Only JERRY BUILT touches my motor.
Old Sep 14, 2004 | 07:21 PM
DefiantGSR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EdBoon &raquo;</TD></TR><TR><TD CLASS="quote">Whoa there keyboard warrior...I know ur hot **** with ur full race car bustin 11s...but I don't see a problem in gathering input about reliability issues.</TD></TR></TABLE>
LOL. keyboard warrior.
Old Sep 15, 2004 | 12:03 AM
rjay8604's Avatar
Default Re: 85mm too much for the street? (Manuel)
Well I know people are worried about 85mm possibly transferring too much heat with the thin cylinder walls left over. I'm gonna be running 85mm bore as well, so bump to this thread. I bet earl would have some good input. or vince from golden eagle.
Old Sep 15, 2004 | 12:44 AM
Quitripin's Avatar
my b18c1 has a 86mm on 12.5:1 with a 95mm crank. You'll be fine.
Golden Eagle Kicks a$$
90blkteg
Dec 3, 2007 10:42 AM
flangemastermike
Mar 15, 2007 07:22 PM
careawholelot
Aug 29, 2005 07:42 AM
95BlkGSR
Oct 26, 2004 08:15 PM
Maxboost00
Oct 1, 2004 10:42 PM
