Compression Question
Old Nov 21, 2007 | 12:35 PM
90blkteg's Avatar
Default Compression Question
What is the safest and highest copression can you run on a ls/v build?
Old Nov 21, 2007 | 01:33 PM
Schister66's Avatar
Man U FTW
It depends...are you running OEM pistons?? The valve reliefs may not allow you to go too high. Also, your fuel choice will limit you. It really depends on how "streetable" you want it to be and how much money you plan to dump into it...
Old Nov 27, 2007 | 02:46 PM
90blkteg's Avatar
Default Re: (Schister66)
85mm bore and I want about 12 cr. This will not be a street car
Old Nov 28, 2007 | 04:36 AM
Options's Avatar
All Secrets Known
Default Re: (90blkteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blkteg &raquo;</TD></TR><TR><TD CLASS="quote">85mm bore and I want about 12 cr. This will not be a street car</TD></TR></TABLE>
Why is 12 cr the magic number for you?
Old Nov 28, 2007 | 08:18 AM
1bad-eg's Avatar
Default Re: (Options)
I agree with Options.....if it's not a street car, you can go all out.....
Old Dec 3, 2007 | 10:42 AM
90blkteg's Avatar
Well I'm open for better suggestions on a better setup
snaileg
Sep 7, 2008 08:48 AM
Maxboost00
Oct 1, 2004 10:42 PM
EdBoon
15
Sep 15, 2004 12:44 AM
krazie1
May 29, 2004 08:57 AM
TurboSam
Oct 15, 2003 06:46 AM
