Afer MPFI install
Old Aug 29, 2004 | 09:32 AM
Bignasty's Avatar
Default Afer MPFI install
I got my MPFI in and working, but I have a question. When I hit the gas it whistles very loudly but the more gas I give it, it shuts up, is this normal? I am figuring that maybe there was some kind of plemun tube used to quieten this down that I dont have.
Old Aug 29, 2004 | 10:12 AM
hatchinprogress's Avatar
Default Re: Afer MPFI install (Bignasty)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bignasty &raquo;</TD></TR><TR><TD CLASS="quote">I got my MPFI in and working, but I have a question. When I hit the gas it whistles very loudly but the more gas I give it, it shuts up, is this normal? I am figuring that maybe there was some kind of plemun tube used to quieten this down that I dont have.</TD></TR></TABLE> i have the same problem it makes noise at certain rpms (even on freeway) alot of people say it has somethin to do with the intake, but i (stupidly) drove my car last nite with no air box or intake, still had the problem, and also i've been told one of my belts might be on to tight??? hope that leads you in the right direction?
Old Aug 29, 2004 | 10:42 AM
EeeJayEight's Avatar
check ur idle adjustment screw...i had the same problem after my swap...just turn it a little either way if its not at the stock setting...you can tell that it hasnt been tampered with because the screw on the throttle body is covered with some silicone or something...i had to search this problem but couldnt find anything...HT members helped me out...if ur not sure what ur doing dont mess with it...cuz adjusting the idle is fine tuning i heard...a friend did it for me
Old Aug 29, 2004 | 12:40 PM
fourthgenhatchB17's Avatar
Default Re: Afer MPFI install (wHiTe91hAtChBaCk)
It does have to do with the idle screw.
Old Aug 31, 2004 | 08:15 AM
Default Re: Afer MPFI install (fourthgenhatchB17)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fourthgenhatchB17 &raquo;</TD></TR><TR><TD CLASS="quote">It does have to do with the idle screw.</TD></TR></TABLE> then what do you think it could be?
Old Aug 31, 2004 | 02:03 PM
Default Re: Afer MPFI install (hatchinprogress)
Try turning it in or out and it should go away. I have experienced the same thing on my old SOHC ZC. One day i adjusted the idle very slightly, and that night it occurred to me that i no longer could here the whistle. The next day i turned it like 1 complete turn in the opposite direction i did the day before, and wha-laa, the whistle was back.
Old Aug 31, 2004 | 02:06 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchinprogress &raquo;</TD></TR><TR><TD CLASS="quote"> i have the same problem it makes noise at certain rpms (even on freeway) alot of people say it has somethin to do with the intake, but i (stupidly) drove my car last nite with no air box or intake, still had the problem, and also i've been told one of my belts might be on to tight??? hope that leads you in the right direction?</TD></TR></TABLE>
Try driving the car with a STOCK airbox and tube, as well as the resonator behind the bumper and see if u still hear it. The stock system is designed to keep all those noises to a minimum, if not completely muffle them altogether.
Old Aug 31, 2004 | 03:32 PM
mengo_charged's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fourthgenhatchB17 &raquo;</TD></TR><TR><TD CLASS="quote">Try turning it in or out and it should go away. I have experienced the same thing on my old SOHC ZC. One day i adjusted the idle very slightly, and that night it occurred to me that i no longer could here the whistle. The next day i turned it like 1 complete turn in the opposite direction i did the day before, and wha-laa, the whistle was back.</TD></TR></TABLE>
I second this method. I had the same situation after I just finished my MPFI swap. But playing with the idle screw was just a coincidence for me. Then I realized after playing with it, the loud whistle noise was gone.
Old Aug 31, 2004 | 03:51 PM
Default Re: Afer MPFI install (mengo_charged)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mengo_charged &raquo;</TD></TR><TR><TD CLASS="quote">
I second this method. I had the same situation after I just finished my MPFI swap. But playing with the idle screw was just a coincidence for me. Then I realized after playing with it, the loud whistle noise was gone.</TD></TR></TABLE>
Same here. I ended up leaving at the setting where it made the whistle. I liked the whistle
boongley29
Acura TSX
25
Sep 19, 2007 01:52 PM
w0ng_sta
Jun 16, 2006 05:04 PM
GsR92HaTcH
29
Apr 24, 2006 08:09 AM
96CXhatch
22
Sep 25, 2005 12:08 AM
comptechgsr
Jun 8, 2003 09:56 AM
