What size tial spring should i use?
Old Aug 26, 2004 | 08:33 AM
lanojp1's Avatar
Default What size tial spring should i use?
Buying my tial 38/40mm gate in a few minutes or so...im looking to boost around 1 bar give or take...what are the rules for wastegate springs? do you buy the spring to match the boost you want or do you buy a smaller spring say 12 psi or so...i will also be using a manual boostcontroller...
Old Aug 26, 2004 | 08:38 AM
juka's Avatar
Get a spring for the lowest boost you ever want to run. Use the MBC to tweak up to your highest boost point.
Example: I have an 8.7lb spring, and will have a MBC to turn up to 12lb.
Old Aug 26, 2004 | 08:41 AM
lanojp1's Avatar
Default Re: (juka)
thanks dude...i guess im gunna get a 10lb spring...
Old Aug 26, 2004 | 10:01 AM
Touge Tuning's Avatar
i believe you should get a spring that is just over half of what you plan to run max. I have heard you can only run double the psi setting of the spring.
Project_EK
Jun 2, 2009 09:33 AM
ntoxicatedtigah
Apr 26, 2009 01:24 PM
dunkd
Feb 3, 2005 11:45 AM
gdrum
Feb 24, 2004 01:55 PM
Short Round
Nov 12, 2003 10:16 PM
