Can i get 18PSI out of a 8psi spring w/BC?
Im going to get tuned next week. I plan on running 18psi max. Can i use a big yellow (8.70psi) spring, how much over spring lbs can i go?
BTW: this is a tial 44mm WG and ill be using a MBC
Re: Can i get 18PSI out of a 8psi spring w/BC?
you should be able to.my car has a 5psi spring and im currently running 18psi with my mbc.i always thought you were suppost to use a real weak wastegate spring when using any type of boost controller.
i'd say it would have been made sooner with more power under the curve had you had a stiffer spring in it, and been more consistent ;-)
