Wastegate Spring Question?
Old Apr 25, 2009 | 11:27 PM
ntoxicatedtigah's Avatar
Default Wastegate Spring Question?
Ok so i have been searching and still on FI faq thread its not on there either. I'm just a little confused on the springs. So i'm guessing the spring in your wastegate needs to be less than the amount of bars/psi yours running? so lets say you want to run 15 pounds, you want a spring under that with a boost controller to get it to 15?
please help me clear this up. thanks.
Old Apr 26, 2009 | 04:58 AM
Adriano's Avatar
Default Re: Wastegate Spring Question?
The spring color/psi ratings is the lowest psi the spring will hold. So if you want 15psi, you want something smaller or just a 15psi without a boost controlle.
Adriano
Old Apr 26, 2009 | 11:32 AM
anything bad on the spring if your running too low of a spring, high boost?
Old Apr 26, 2009 | 01:15 PM
gvg's Avatar
gvg
certain springs hold certain loads
get a spring with in mind of what psi you want to run(minimum)
if eg its an 7psi spring it will def not hold 25psi
Old Apr 26, 2009 | 01:24 PM
grndcont's Avatar
the rule of thumb seams to be x2. so i you want to run a max of 15 lbs, but use a controller to run under that sometimes, the smallest you should run i a 7.5 lb spring.
suposidly the light spring starts to flutter after 200% of it's rated psi.
Pumpking.
Nov 2, 2016 09:35 AM
ctownintegra
Jul 9, 2008 02:41 AM
dunkd
Feb 3, 2005 11:45 AM
Lucky_Smurf
Sep 22, 2004 06:31 AM
Short Round
Nov 12, 2003 10:16 PM
