My Boosted GSR wont turn over this morning! Help! Only click on crank!
Assuming the "click" is coming from the starter (which it usually is) it sounds like you need a new starter. The click you are hearing is probably the solenoid engaging the gears to the flywheel. At the same time this is also supposed to make contact with the starter motor which turns the engine over. Most common problem with starters is that these contacts wear out, and then you just have the bendix engaging the fly wheel. (only a click)
i disagree and agree with you...however my teg was just doing the same thing and it ended up being the battery...the clicking noise is the starter but that doesnt mean that it is bad...check your battery...even though that little dot on the battery says that its good its not b/c mine showed good but i had to recharge it and it worked fine after that...
so first check your battery...use another battery to see if it'll turn over..if it does then just replace your battery...second if it still clicks then its your starter...
I can hear a click under the dash fuse box.. and another from under the hood fuse box..
Would it be possible to be my battery? Even Tho its possible to manually Jump start my car (using another wire from the battery to the Starter) I can jump start my car manually, and it runs... Just that it wont start inside.. So i assume the starter is still good.
After manually running the car for 30 minutes, the battery shouldbe charged.... Yet, the motor wont crank still!
Any other suggestions? ( I will try to swap battery and see how it goes)
From: Formerly of SF moved to DFW and now back in SF, CA, USA
If the battery is dead it won't hold a charge. Bring the battery to a auto store and have them test it if you are not sure. Then buy a new battery cuz your old one is toast.
