Some Vac and boost questions...
Old Aug 19, 2004 | 04:53 PM
G3NR8's Avatar
Default Some Vac and boost questions...
I searched but didn't find anything close enough...
Basically, I've tried 2 different WG actuators on my 14b turbo (d16y8). I know both of them open because I used a compressor and sprayed air through them today while they were hooked to the WG flapper. My problem is that they do not seem to open at all while driving. I have my BOV, FPR, and boost gauge tapped off the intake manifold, and I have the WG actuator tapped off the nipple coming off the charge pipe on the turbo. Neither of the WG's seem to be getting enough air to open. The only thing I'm not sure of is what PSI they are set at. The person I bought them from said they were 7psi, but even after 10 psi they aren't opening. I definetely don't want to be above 8psi right now....any ideas????
Old Aug 19, 2004 | 05:45 PM
beepy's Avatar
Default Re: Some Vac and boost questions... (G3NR8)
You need to take the boost signal from the nipple on the compressor housing, as per stock. Otherwise you will make much more boost than you want!
luly-rast
Feb 10, 2012 04:49 PM
ragethemachine86
Sep 12, 2006 07:58 PM
turbotime
Sep 26, 2005 06:22 AM
ludelvr
Aug 25, 2002 10:40 PM
