B18C5 into a 90 civic hatch back, anyone?
Old Aug 18, 2004 | 04:14 PM
nomotor's Avatar
Default B18C5 into a 90 civic hatch back, anyone?
im just wondering who has done this swap on their obd-0 car? and how crazy would the wireing be? cuz i heard that it would be ridiculous, convering obd-0 to obd-1 then convering the obd-2 type R engine to obd-1 and finally coming to running the car obd-1 status.
Old Aug 18, 2004 | 05:01 PM
Superhatch's Avatar
Default Re: B18C5 into a 90 civic hatch back, anyone? (nomotor)
I need to make a stamp. *stamps* Upper right hand corner...search button. *lifts stamp*
Old Aug 18, 2004 | 05:05 PM
nomotor's Avatar
Default Re: B18C5 into a 90 civic hatch back, anyone? (Superhatch)
i did bia, the search feature is one of the gayest
Old Aug 18, 2004 | 05:07 PM
LSVTEC 91 Civic's Avatar
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nomotor &raquo;</TD></TR><TR><TD CLASS="quote">i did bia, the search feature is one of the gayest</TD></TR></TABLE>
Old Aug 18, 2004 | 05:13 PM
Superhatch's Avatar
Default Re: B18C5 into a 90 civic hatch back, anyone? (LSVTEC 91 Civic)
https://honda-tech.com/zerothread?id=727051
https://honda-tech.com/zerothread?id=655749
https://honda-tech.com/zerothread?id=592051
https://honda-tech.com/zerothread?id=525600
https://honda-tech.com/zerothread?id=459249
Perhaps 5 minutes of searching for b18c5 in the EF forum. All contain at least 1 post about the wiring differences between the two OBD's.
Old Aug 18, 2004 | 05:32 PM
nomotor's Avatar
i have a std. 4 speed though
Old Aug 18, 2004 | 05:35 PM
Superhatch's Avatar
Do you want me to look through all of the possible posts about conversions? They are on here....please...Im begging you....do a search on your own, and spend more than 19 min looking.
Odds are unless you just stroked a d series into a 1.7L (which has now been done ) with stock honda parts....its been covered on this site. Prove me wrong and Ill paypall you $5usd.
Old Aug 18, 2004 | 06:13 PM
CRXBart's Avatar
Yeah dude learn to search, there is a ton of info on this forum. Basicly you need to do a b-series swap, and an obd-1 conversion. It's really easy stuff, and like you stated before you have to convert the motor to 0bd-1 also. It's not that big of a deal.
Old Aug 18, 2004 | 06:33 PM
nomotor's Avatar
Default Re: B18C5 into a 90 civic hatch back, anyone? (CRXBart)
cluster ****
Old Aug 18, 2004 | 07:45 PM
Rywire's Avatar
Here is a little site that I just started, makes wiring a snap. http://www.geocities.com/droppedcrxsi_wiring
Ryan
Old Aug 18, 2004 | 08:30 PM
StorminMatt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nomotor &raquo;</TD></TR><TR><TD CLASS="quote">im just wondering who has done this swap on their obd-0 car? and how crazy would the wireing be? cuz i heard that it would be ridiculous, convering obd-0 to obd-1 then convering the obd-2 type R engine to obd-1 and finally coming to running the car obd-1 status.</TD></TR></TABLE>
Swapping in a B18C5 is no more difficult than swapping in a B18C1. As for the wiring, if you use a 1996-1998 JDM P73, it is no more difficult to wire up the ECU plugs than, say, a P28 or P30. In fact, it is a little easier since you don't have to worry about a purge valve or VTEC pressure switch. If you go with the 1996-1998 USDM P73, it is only a little more difficult than a 1992-1995 ECU, since you only have to worry about wiring a second oxygen sensor in addition to the OBDI sensors. 1999+ ECUs are MUCH more difficult to wire up in a 1988-1991 car.
HondaRexBoi
Apr 20, 2021 11:52 PM
vtecspeed1320
11
Nov 5, 2006 10:22 PM
turbob16ef
Dec 31, 2005 07:09 AM
Panario
Dec 1, 2005 05:22 PM
civic91si
Jun 5, 2005 05:27 PM
