Symptoms to turbo gone bad?
Old Aug 16, 2004 | 06:49 AM
Superesc's Avatar
Default Symptoms to turbo gone bad?
Trying to figure out if my turbo is toasted. Wondering what are some of the symtoms?? Any help would be much appreciated. Thx!
(It's a T04E 50 trim w/.60 A/R compressor. T3 turbine .48 A/R with a stage 3 wheel)
-Calvin
Old Aug 16, 2004 | 06:52 AM
D-Man's Avatar
Default Re: Symptoms to turbo gone bad? (Superesc)
oil burning,lots of shaft play,turbine doesnt spin freely or not at all.
Old Aug 16, 2004 | 07:58 AM
m R g S r's Avatar
In my case, oil was coming out of the inlet on the compressor side. ..
Old Aug 16, 2004 | 08:30 AM
TheShodan's Avatar
Moderator
If you feel the turbo is damaged, it would help if you told us some symptoms that you're experiencing. Or check online for other turbo "problems". No one can diagnose problems w/o symptoms..
Old Aug 16, 2004 | 12:36 PM
Superesc's Avatar
Default Re: (TheShodan)
It feels like its spooling much later (starts spooling at 3/35k) then what it was before... at first I thought it was charge pipe, but I check over and over again and couldn't see any pipe lose (all Tbolts)... The only thing I haven't really throughly checked is the couplers if they have a ripe or not, I only feel around all of them and seem ok... I only have my turbo for 3 weeks so everythings pretty new...
I am not burning any oil, and the wheel seem to turn freely...
-Calvin
Old Aug 16, 2004 | 01:18 PM
Chris F's Avatar
Default Re: (Superesc)
If there's a problem, it's probably a leak somewhere, either exhaust or intake. Hmm. Probably easiest to find on a dyno. If your turbo is spinning and not leaking it's probably still just dandy.
It could definitely be tuning or something along those lines. Do you have a wideband O2 sensor? What about a boost gauge? When did you expect it to spool, 3000-3500 sounds pretty good.
Old Aug 16, 2004 | 02:08 PM
Superesc's Avatar
Default Re: (ccfries)
yea it may be alright and I am just paranoid Will tighten my manifold tonite as I haven't done so since the install... Hopefully that will fix it.
Old Aug 16, 2004 | 02:43 PM
Phil Koury's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ccfries &raquo;</TD></TR><TR><TD CLASS="quote">It could definitely be tuning or something along those lines. Do you have a wideband O2 sensor? What about a boost gauge? When did you expect it to spool, 3000-3500 sounds pretty good.
Tuning technically would not cause the turbo damage in any way.
If you have a pre-turbine exhaust leak it will cause the turbo to not build boost as quickly or cause the turbo to work harder to build and maintain boost. I would tighten everything down first, and then check all the connections.
3000rpm is pretty decent for your turbo.
Old Aug 16, 2004 | 03:02 PM
Chris F's Avatar
Default Re: (pkoury)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pkoury &raquo;</TD></TR><TR><TD CLASS="quote">
Tuning technically would not cause the turbo damage in any way..</TD></TR></TABLE>
Well he probably doesn't have turbo damage. I agree with that. I meant that a bad tune could cause it to feel slow.
but you could damage the turbo with tuning, just run a little lean with too much ignition retard and you could burn that sucker up with high EGT's
Old Aug 16, 2004 | 05:51 PM
BB6-213's Avatar
But running rich, with alot of igniton retard wouldn't burn it up right?
Old Aug 17, 2004 | 05:50 AM
Chris F's Avatar
Default Re: (BB6-213)
Probably not. EGT measurements would be the best way to figure out.
freakie
Mar 4, 2007 12:33 AM
steve96accord
Jun 30, 2006 09:40 PM
fastcivicboy
Feb 9, 2006 09:22 PM
Dampach1
Oct 12, 2005 11:13 AM
MisterB
Nov 7, 2001 05:13 PM
