Timesert / Stripped Spark Plug Hole in ITR Head
I just picked up a ITR swapped hatch and have discovered a big problem. One of the spark plug holes is stripped.
I am planning on using a Timesert to fix the stripped hole. I have a technical question about which insert to buy.
Basically I need to know the depth of the threaded area in an ITR head. I know the 'reach' of the spark plugs is 0.75"
I don't want to put in an insert that is too long or too short. Can anyone measure the thread depth on a spare head for me? Or post up a picture of a removed head with a spark plug fully installed?
Thanks!
Thanks!
Re: Timesert / Stripped Spark Plug Hole in ITR Head (boomslang)
well just look at how much carbon if any is on the threaded part, if none then it dosent go below the hole i dont think they do at all so you should be fine with one the same length as the threads on the plug,
F4nunez
Honda Civic (2001 - 2005)
06-18-2019 06:33 PM
