Fuel Filter changing
Old Aug 3, 2004 | 05:31 PM
shabasoft's Avatar
Default Fuel Filter changing
I have a 1994 2.2 VTEC import.
I want to change the fuel filter and know that it is on the right of the fuse box from what i have read..?
Can someone send me a pic of it and a step by step instruction of how to change it?
thanks
Old Aug 3, 2004 | 06:55 PM
vteckilla7's Avatar
Default Re: Fuel Filter changing (shabasoft)
it's the little canister thing to the right of the fuse box i 14 mm wrench will do the trick on th top fuel will leak out, i think there is 4 10 mm bolts holding the bracket on it's really simple to change.
Old Aug 3, 2004 | 08:04 PM
AznBlueBoy's Avatar
Default Re: Fuel Filter changing (vteckilla7)
its in a tight spot...you might need to take off the intake to get to it?
Old Aug 3, 2004 | 09:09 PM
SuperSlow's Avatar
I did a search on this particular topic and found about 20 hits in this forum. Check it out.
Old Aug 4, 2004 | 06:49 AM
-Bionic-'s Avatar
Former Sponsor
Default Re: Fuel Filter changing (SuperSlow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuperSlow &raquo;</TD></TR><TR><TD CLASS="quote">I did a search on this particular topic and found about 20 hits in this forum. Check it out.</TD></TR></TABLE>
lol
Old Aug 4, 2004 | 09:34 AM
equinox's Avatar
remember to remove the gas cap to alleviate fuel pressure, you don't want fuel sprayin on your face when you remove the fuel filter.
Old Aug 4, 2004 | 09:50 AM
Nikoli's Avatar
Default Re: Fuel Filter changing (lude_roller)
its a pretty straight forward job. although its in an awkaward place and the bolts/nuts might be little hard loosen at first. other than its easy. pretty self explanitory
Old Aug 4, 2004 | 10:05 AM
94vtecmn's Avatar
Default Re: Fuel Filter changing (Deckedlude)
The easiest way to remove it will be with a line wrench, not your run of the mill open ended wrench. A line wrench has two more sides to keep it from slipping on the nut
Old Aug 4, 2004 | 01:04 PM
2.2XDreams's Avatar
Default Re: Fuel Filter changing (94vtecmn)
not to thread jack but how often should the fuel filter be replaced? my car has 98xxx miles on it and ive owned it for the past 20xxx and never done it and i dont think the owner before me did either...
Old Aug 4, 2004 | 01:11 PM
Behan's Avatar
Default Re: Fuel Filter changing (2.2XDreams)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2.2XDreams &raquo;</TD></TR><TR><TD CLASS="quote">not to thread jack but how often should the fuel filter be replaced? my car has 98xxx miles on it and ive owned it for the past 20xxx and never done it and i dont think the owner before me did either...</TD></TR></TABLE>
Off the top of my head i beleive it is recommended every 30,000 miles.
So in other words, CHANGE YOUR FUEL FILTER
vltnolia
Feb 14, 2007 11:24 AM
manyakiexpi
Mar 3, 2006 04:26 PM
Rpizzle
Apr 7, 2005 09:37 AM
handa
Apr 3, 2005 03:27 PM
andrewasf77
Dec 6, 2002 10:30 PM
