need some help: stripped bolt
Old Jul 10, 2004 | 01:10 PM
TURBOFTW's Avatar
Default need some help: stripped bolt
Hi there i recieved a motor and it came without a flywheel that being said i had it built its an LS block im in the process right now of putting it back together and noticed that one of the crank hole(for flywheel) were stripped very bad beyond using a tap...my question is can i run it without one bolt? any help would be great thanks....
Old Jul 10, 2004 | 01:14 PM
illicon2003
Guest
Posts: n/a
I'm not an expert but I'd be really careful running without that particular bolt. Your clutch/flywheel could potentially misalign and cause your transmissions gears to tweek a bit. I think. If i'm wrong, then cover the area with high temp gasket maker. **** call the honda dealership and speak with one of the real mechanics they will know for sure. Also, make sure that they know you are mechanically inclined cause one time the mechanic told me that the car probobly wouldn't start with a bad 02 sensor.
Old Jul 10, 2004 | 01:15 PM
navin's Avatar
Default Re: need some help: stripped bolt (h22dude)
I wouldnt run it w/o the bolt - flywheel attaches to the crank..
just think of it being out of balance w/o that last bolt there...
Old Jul 10, 2004 | 01:16 PM
TURBOFTW's Avatar
Default Re: (illicon2003)
the flywheel is still aligned with the crank i have the rest of the bolts in i just dont have one....
Old Jul 10, 2004 | 01:22 PM
TURBOFTW's Avatar
Default Re: (h22dude)
anyone else?
Old Jul 10, 2004 | 02:53 PM
turbolshatch's Avatar
i would get it heli coil or time sert but i would want to run it without that bolt... there is a lot of force being transfered through those bolts
Old Jul 10, 2004 | 03:05 PM
TURBOFTW's Avatar
Default Re: (turbolshatch)
i went to try and buy a tap i exammed the threads better and it could be tapped but no one has a tap... checkers,ace,home depot,autozone....no where i need 12mm by 1.00 fine pitch.....
Old Jul 10, 2004 | 05:08 PM
well do u guys have brafasco or other bolt suplier around if so try them
CivicUtah
16
Sep 21, 2007 02:14 PM
M.A.R.C.
Jan 18, 2006 05:49 PM
TURBOFTW
Jul 10, 2004 03:21 PM
Scooby
Jun 28, 2002 01:07 PM
