Just Dynoed Today.. Check it out!! Just in time for the track too
I just dynoed my new setup today on a Mustang Dyno @ Payn Tech.. took me about a month getting it all together for today too.. the last week was pretty hectic, had to completely redo my oil return line cuz it was leaking..
anyway, I managed to pull a best of 351 HP/243 TQ w/ my fully built 84mm sleeved GSR on Pump Gas .. Tt was a great jump from my last tuning session in which i only pulled a mere 197 HP last fall...
Here's my Setup, Let me know how i fared to others out there w/ similiar setups..
Hondata S200b
Benson Sleeved 84 mm bottom end
9:1 weisco's / eagle rods 3/8"
REV valve springs
SC61 @ 16-17 psi
PTE 600 HP FMIC
JG IM
750 RC's
3" full exhaust & DP
RPS clutch
2.5" charge piping
walbro 255
& some other stuff...
I"m hoping to run 11's this saturday, but will probably actually do low 12's realistically..
Modified by 92HB_HB at 1:58 AM 7/2/2004
Hondata S200b
REV valve springs
SC61 @ 16-17 psi
PTE 600 HP FMIC
JG IM
750 RC's
RPS clutch
2.5" charge piping
walbro 255
Congrat! Nice numbers...but still a little low for the boost you're running. Mike01GSR made over 500 with 18psi. I'm thinking you should be around there too no? But still great numbers.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cinq »</TD></TR><TR><TD CLASS="quote">Congrat! Nice numbers...but still a little low for the boost you're running. Mike01GSR made over 500 with 18psi. I'm thinking you should be around there too no? But still great numbers.
</TD></TR></TABLE>^On pump gas?.
Nice numbers get some REAL gas in there goodluck at the track
</TD></TR></TABLE>^On pump gas?.Nice numbers get some REAL gas in there goodluck at the track
**** man that's awesome!!!
That's basically 90% my setup, I know this is a lot to ask, but if you got hondata would you be willing to send me the MAP?
Look at my post, ****, I wish i had your #'s, this is what I was expecting.
here's my link, give me a PM if you like.
https://honda-tech.com/zero...age=1
well we put in 100 octane and boosted up to 20 psi.. the car started misfiring up top, so we stopped and just called it a day w/ 17 psi.. it seems my stock ignition isn't cutting it w/ 20 + psi....
overall, i'm happy w/ what i got today.. btw, my 1st pull of the day netted 315 HP on a base map pull.. That suprised us all...
i've got to get used to this power b4 i decide to upgrade my ignition and pour race gas into the mix...
92HB_HB
Jul 11, 2004 07:11 PM
