How to upgrade fuel on turbo applications?
Old Jun 30, 2004 | 06:02 PM
92civiclsb18a's Avatar
Default How to upgrade fuel on turbo applications?
what do i need to add to my fuel system for a turbo application?
92 civic hb b18a
kKdARIAN's Avatar
Vice President/CEO
Default Re: How to upgrade fuel on turbo applications? (92civiclsb18a)
fuel pump, bigger injectors.... what is your fuel managment?
Old Jun 30, 2004 | 06:05 PM
SolObsession's Avatar
Many choices, try searching the FI forum.
Fuel pump, adjustable fuel pressure regulator, injectors.
For management you have many many choices...AEM EMS, Hondata, Uberdata, FMU, many more just search.
Old Jun 30, 2004 | 06:46 PM
Default Re: How to upgrade fuel on turbo applications? (kKdARIAN)
No fuel management just stock p05 ECU. I'm wanting to try and boost at least 10 psi. Should I just chip the ECU or go another route?
Old Jun 30, 2004 | 06:52 PM
wow, wow, wow. in order to boost you NEED fuel management. You cannot go turbo without it, esp. at 10 psi. You NEED at a MINIMUM a Missing Link, 12:1 FMU 310 or 440 injectors and Fuel Pump. You should get a better one but I am done helping you cuz you refuse to search and post in the correct forum.
Old Jun 30, 2004 | 06:58 PM
Default Re: How to upgrade fuel on turbo applications? (SolObsession)
Thanks for the information. Kinda harsh though. But I do learn from my mistakes. Will do next time. Thanks.
Old Jun 30, 2004 | 08:41 PM
.::Lee::.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SolObsession &raquo;</TD></TR><TR><TD CLASS="quote">wow, wow, wow. in order to boost you NEED fuel management. You cannot go turbo without it, esp. at 10 psi. You NEED at a MINIMUM a Missing Link, 12:1 FMU 310 or 440 injectors and Fuel Pump. You should get a better one but I am done helping you cuz you refuse to search and post in the correct forum. </TD></TR></TABLE>
Careful though, you shouldn't use all those together
You can use a missing link in conjunction with an FMU and some consider that fuel management.
But if you are going to upgrade injectors (recomended), you really need something to control them, such as chipping your ecu, or you could use a SAFC to control them if it comes down to it.
90crxsi88zc
Oct 6, 2005 03:18 PM
92civiclsb18a
Jul 3, 2004 02:16 AM
RNPoo7
Jun 30, 2003 08:55 PM
2k1civicturbo
Jan 23, 2003 10:43 AM
riot
Feb 10, 2002 11:18 AM
