FMU ...PLEASE READ
Old Jun 28, 2003 | 08:57 PM
RNPoo7's Avatar
Default FMU ...PLEASE READ
when having a turbo ...do you need a fmu even if you have the fuel pump, injectors and a fuel regulator?
If yes..what is the best for D16Y8 with TDh04-15G
Old Jun 28, 2003 | 09:00 PM
Flamenco-T's Avatar
Default Re: FMU ...PLEASE READ (RNPoo7)
YES, unless you're running AFC hack, or standalone such as hondata.
Fuel regulator can only control static base fuel pressure. FMU will increase the fuel pressure as it sees boost. No boost, no increase in fuel.
Standalone add fuel by changing or manipulating injectors duty cycle.
stan
Old Jun 29, 2003 | 05:29 AM
toxicshit's Avatar
with a honda ECU and no boost understanding fule system: Yes
With a stand alone Fule system that understands boost: no
Old Jun 29, 2003 | 08:52 AM
RNPoo7's Avatar
So what if you have a SKUNK2 ECU along with fuel pump, injectors, and the fuel regulator...do you still need the FMU ?
Old Jun 29, 2003 | 09:25 AM
X2BOARD's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RNPoo7 &raquo;</TD></TR><TR><TD CLASS="quote">So what if you have a SKUNK2 ECU along with fuel pump, injectors, and the fuel regulator...do you still need the FMU ?</TD></TR></TABLE>
Skunk2 makes boost ECUs ? Didn't know that...
If it's not a boost ECU, but an N/A w/ remapped fuel... DON'T Boost on it... the ignition maps are drastically different.
Old Jun 30, 2003 | 08:55 PM
RNPoo7's Avatar
Default Re: FMU ...PLEASE READ (X2BOARD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by X2BOARD &raquo;</TD></TR><TR><TD CLASS="quote">
If it's not a boost ECU, but an N/A w/ remapped fuel... DON'T Boost on it... the ignition maps are drastically different.</TD></TR></TABLE>
You are right.. Sorry, SKUNK2 makes ECUs for only N/A cars.
lyncoors
Feb 1, 2010 11:54 PM
themorphious
Mar 4, 2006 08:49 PM
90crxsi88zc
Oct 6, 2005 03:18 PM
92civiclsb18a
Jun 30, 2004 08:41 PM
T3EMSI
Jun 5, 2002 08:30 AM
