integra rs non-abs swap
Old Jun 28, 2004 | 03:29 PM
98ITRWhite's Avatar
Default integra rs non-abs swap
how much work is in doing this, and what parts do you need?
Old Jun 28, 2004 | 03:33 PM
Kendall's Avatar
You need the RS master cylinder, proportioning valve and the front hard lines. I don't believe you need the rear hard lines, but I could be wrong. From the standpoint of complexity, it's rather simple, however it's a royal pain in the *** to run hard lines.
Old Jun 28, 2004 | 04:00 PM
98ITRWhite's Avatar
Default Re: (Kendall)
the motor is out and the engine bay is striped down tobe painted so now is the perfect time if i am going to do it.
Old Jun 28, 2004 | 04:06 PM
Kendall's Avatar
Default Re: (98ITRWhite)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98ITRWhite &raquo;</TD></TR><TR><TD CLASS="quote">the motor is out and the engine bay is striped down tobe painted so now is the perfect time if i am going to do it. </TD></TR></TABLE>
Even without an engine, redoing the hard lines is still a pain in the ***, but I agree, now is the opportune time.
Old Jun 28, 2004 | 04:22 PM
Flux's Avatar
Default Re: integra rs non-abs swap (98ITRWhite)
Can I ask why you would do this? I'm not being sarcastic - the ITR ABS system is one of the best IMO and was wondering what the reason would be to ditch it...
Old Jun 28, 2004 | 04:26 PM
Kendall's Avatar
Default Re: integra rs non-abs swap (Flux)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flux &raquo;</TD></TR><TR><TD CLASS="quote">Can I ask why you would do this? I'm not being sarcastic - the ITR ABS system is one of the best IMO and was wondering what the reason would be to ditch it...</TD></TR></TABLE>
The fact that proper threshold braking can stop you just as quickly if not quicker, plus the fact that there will be quite a bit of weight saved as compared to the ABS system.
Old Jun 28, 2004 | 05:10 PM
esponet's Avatar
you need the following non abs parts:
master and booster.front lines, proportioning valve, and the lines to the proportioning valve.
no need to replace the rear lines, for one its a bitch to do so, (you need to drop the tank for that.) just simply massage in place.
Old Jun 28, 2004 | 05:21 PM
George Knighton's Avatar
H-T Order of Merit
Default Re: integra rs non-abs swap (Kendall)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall &raquo;</TD></TR><TR><TD CLASS="quote">
The fact that proper threshold braking can stop you just as quickly if not quicker....</TD></TR></TABLE>
If you think that "proper threshold braking" is better than ITR ABS on a dry road course, then you are living as if the ABS technology from the 80's is what you're dealing with.
You're not.
ITR ABS is really quite good. You will be outbraking a hell of a lot of expensive machines in Summit T 5 even with ABS.
Realistically, however, if you are advanced enough that you are even thinking about removing the ABS, then you are probably on R compounds.
From personal experience, if you're on A032R or something like that, you will still be using the ABS if you have it. If you are on Hoosiers, you might think about removing the ABS because you will very seldom be in a situation where you will exert (or even want to exert) enough clamping force to overpower the grip of the Hoosiers.
Spec VR on an ITR can overpower Hoosiers to the point ABS kicks in, but you really, really have to try.
We should ask some of the Honda Challenge drivers like Jason Franza about this. I believe he kept his ABS and finds it an advantage. I believe Adam Curpier also kept his ABS.
Old Jun 28, 2004 | 05:22 PM
ZygSpeed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall &raquo;</TD></TR><TR><TD CLASS="quote">The fact that proper threshold braking can stop you just as quickly if not quicker, plus the fact that there will be quite a bit of weight saved as compared to the ABS system.</TD></TR></TABLE>
Threshold braking is nice in theory, many of the latest H1 cars wish they had ABS in conjunction with their big brake kits.
The weight ... Bah!
Old Jun 28, 2004 | 05:26 PM
1GreyTeg's Avatar
The fact that proper threshold braking can stop you just as quickly if not quicker, .</TD></TR></TABLE>
I find this Extremely hard to believe.
I know National class autocrossers that can't give enough praise to the R's ABS and would Never think of removing it.
And I'm sure you can find more than a few Honda Challenge guys that will agree.
I'd expect anyone removing the system is doing so to satisfy club classing rules mostly, and then weight reduction (as specified in the post below or for a drag car) and then possibly preference:
Read on:
They're talking about a GSR here, not even an R
https://honda-tech.com/zerothread?id=807434
https://honda-tech.com/zerothread?id=665756
https://honda-tech.com/zerothread?id=629200
https://honda-tech.com/zerothread?id=503166
https://honda-tech.com/zerothread?id=326334
https://honda-tech.com/zerothread?id=249986
https://honda-tech.com/zerothread?id=69447
Etc, etc, so on and so forth.
Old Jun 28, 2004 | 05:56 PM
Black R's Avatar
25 Year Member
Default Re: integra rs non-abs swap (1GreyTeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1GreyTeg &raquo;</TD></TR><TR><TD CLASS="quote">
Read on:
.....ditto.
Otherwise I wouldn't have gone through so much time and expense to put the itr 5-lug + ABS on my EF.....
Old Jun 28, 2004 | 05:59 PM
.RJ's Avatar
.RJ
You can still threshold brake with the ITR system - but! It will bail you out when you overstep the boundaries of traction. I would absolutely not remove it.
Old Jun 29, 2004 | 04:10 AM
H-T Order of Merit
I can't believe so many hard heads have actually agreed about something in one thread.
Old Jun 29, 2004 | 06:18 AM
MattD@Stoptech's Avatar
Default Re: (George Knighton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by George Knighton &raquo;</TD></TR><TR><TD CLASS="quote">I can't believe so many hard heads have actually agreed about something in one thread. </TD></TR></TABLE>
I wish I had ABS....maybe i'd win a race for a change....
Old Jun 29, 2004 | 06:21 AM
.RJ's Avatar
.RJ
Seems a bit chilly in hell today...
Old Jun 29, 2004 | 06:24 AM
PM-Performance's Avatar
it is 100x easier with the engine out . its not a hard project at all . ive done it on mine .
just get the prop valve and run new front lines.
and you DO NOT NEED A NEW MASTER CYL.
the only thing that needs to be changed is the PROP VALVE
Old Jun 29, 2004 | 07:16 AM
esponet's Avatar
Default Re: (itr206)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr206 &raquo;</TD></TR><TR><TD CLASS="quote">DO NOT NEED A NEW MASTER CYL.
ooppss i just realize you have a R. yeah you don't need it. when i did it i had a 94 LS. so i upgraded to a 98+ master/booster.
Old Jun 29, 2004 | 08:17 AM
Jon V's Avatar
Default Re: (esponet)
what is different about the RS prop valve?
Old Jun 29, 2004 | 08:25 AM
Default Re: (Jon V)
doesnt have all the ports for the axtra ABS lines. i think the RS one only has like 6 ports
Old Jun 29, 2004 | 09:35 AM
esponet's Avatar
abs don't have prop valve. proportining between front and rear is done through the abs modulator. it has a junction were the pop. valve is suppose to be. but that is just a way for the lines to connect to one another, no valve. so by removing the abs, you need to add a proportioning valve.
btw. i found that a 94RS prop valve is the same as jdm spec R non abs prop valve. and that a 93 gsr mater has the same part # as nsx master. the piston is also bigger.
Old Jun 29, 2004 | 11:59 AM
norice's Avatar
This statement may have been debateable in the early 1980's but is no longer supportable with recent ABS systems.
Also, modern ABS systems are 4 channel so can independently threshold brake each corner. Schumacher himself could not do that (assuming he had the necessary four brake pedals to do it.)
Apart from regulations for a particular racing series demanding it, I cannot think of a single good reason for removing the ITR's ABS system. The minor advantage from the weight savings from removing it would be gone in a corner or two.
1988montecarlos
Suspension & Brakes
Dec 27, 2013 07:52 AM
dE.fUsEd
Apr 2, 2012 04:13 PM
dustinbs144
Mar 6, 2011 06:08 PM
cxhatch93
Oct 22, 2008 06:56 PM
HondaKid_1
Jul 22, 2008 05:09 PM
