getting rid of ABS
im going to the pick n pull and i was wondering if the da or eg proportioning valve will work and what lines to get? my abs is [freak]ed and i want to get rid of it and teh engine is out and its the perfect time to do this. plus IMO its a cleaner engine bay.
what year integra do u have?..an eg prop valve will fit a dc..ur gonna need the 2 lines from the brake booster and the 2 going to the front brakes
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HeyMikeyyyy »</TD></TR><TR><TD CLASS="quote">all u have to do is buy RS 40/40 and ur set
and RS Front break lines!!</TD></TR></TABLE>
That's what I've heard, doesn't sound to bad.
and RS Front break lines!!</TD></TR></TABLE>That's what I've heard, doesn't sound to bad.
Not true. I did everything down to the brake booster and master cylinder from an RS integra. If you want to do this with your stock brake booster and master cylinder, the hard line will not bolt on to the LS/GSR master cylinder. You will have to bend some brake lines to fit or get flexable brake lines.
https://honda-tech.com/zerothread?id=1160671
Pics dont work but you get the idea.....search next time please!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. Carbon Fiber »</TD></TR><TR><TD CLASS="quote">Not true. I did everything down to the brake booster and master cylinder from an RS integra. If you want to do this with your stock brake booster and master cylinder, the hard line will not bolt on to the LS/GSR master cylinder. You will have to bend some brake lines to fit or get flexable brake lines.
Pics dont work but you get the idea.....search next time please!</TD></TR></TABLE>
