ANYONE KNOW ABOUT T04X TURBO???
Old Nov 17, 2001 | 11:29 PM
1's Avatar
Default ANYONE KNOW ABOUT T04X TURBO???
Anyone heard of this one and have details on it?
Old Nov 17, 2001 | 11:33 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: ANYONE KNOW ABOUT T04X TURBO??? (1)
The T04X is the largest compressor wheel in the family. For cheaper you can probably go with a 60-1 turbo which should out flow any T04, but like I said "should".
art
Old Nov 17, 2001 | 11:41 PM
1's Avatar
Default Re: ANYONE KNOW ABOUT T04X TURBO??? (Arturbo)
Art,
Rather a newbie here.... lotsa gumption, little brains. My DRAG kit came with a T04X (don't ask)
I am putting this on my CRVTEC setup with 10.0:1 compression, CTR cams,ITR intake.RC 310 c.c.
Dynoed 178 w.h.p. 133 f.p.t. before installation of turbo. I plan on HKS EVC IV, APEX V-AFC, maybe 94-95 GSR ECU.( Mine is a G2 GSR)
What would you expect this to run with say 8 p.s.i.?
TIA
Old Nov 18, 2001 | 12:00 AM
Arturbo's Avatar
Better than steak
25 Year Member
I dont understand how your drag manifold can bolt up with a T4. The drag manifold can only use a T3 turbine housing. Do you have a T3/T04X? Now, this is just an assumption about how much power you can have. Since the CRV has 10% larger displacement than a Gsr, and I made 277whp, I think you will be over the 300whp+. 304whp or more is what I would expect at 8psi, maybe way more. What do I know?...lol
art
Old Nov 18, 2001 | 12:39 AM
Ray's Avatar
Ray
New User
i think he got a t3/t04x...
EDIT: t3 turbine with t04x compressor.
1 are you amerikan on g2ic?
[Modified by Ray, 9:42 AM 11/18/2001]
Old Nov 18, 2001 | 12:58 AM
paulzy's Avatar
Default Re: ANYONE KNOW ABOUT T04X TURBO??? (Ray)
all I know is that it's freakin' $850+!!!!!!!!!! Plus, XS are kinda secretive about the t04x and the t3/t04x, at least they are on their site.
Old Nov 18, 2001 | 05:40 AM
Turbo_Teg's Avatar
New User
Default Re: ANYONE KNOW ABOUT T04X TURBO??? (Slow_ass_4dr)
I thought xs wanted11-12 hundred for the t04x
Old Nov 18, 2001 | 06:44 AM
1's Avatar
I had to do a little modification in the block area to fit the T04X. I am going to spend the day hooking up my HKS EVC IV and maybe feel some of this monster's power.Are new TIAL wastegates supposed to come with different pressure springs or not?
Ray.....sssshhhhhhhh
Old Nov 18, 2001 | 08:43 PM
Ray's Avatar
Ray
New User
if you have a hks evc4, then you just set the boost higher on the controller. Make sure you program the hks first.
haha 1, I guess you want to be seen as "all knowing" on the other site, ok
Old Nov 18, 2001 | 08:46 PM
1's Avatar
I will be the first one to say I am a newbie!
Ray, there is a provision on the bottom of my throttle body that I just attached back to the charcoal canister. Can I use thisfor a map sensor? How would I go about attaching one?
Oh yeah, It is definitely a T04X. Part of the block had to be shaved to fit the damn thing in there...
[Modified by 1, 9:47 PM 11/18/2001]
Old Nov 18, 2001 | 09:21 PM
SEFIxCivic's Avatar
From what I hear a TO4X is basically XS terminology for a custom turbo. They have a questionaire you fill out about what your setup is and what you like you power band to be, and they go from there. They are real secretive about their stuff and grind off part numbers on their turbos. One time I tried to call them about a turbo I purchased, and they said they didn't even know what was inside because they don't keep files. Lots of people gripe about this.
Old Nov 18, 2001 | 10:10 PM
InfamousDX's Avatar
my boy actually got a new drag kit with a t3/to4x in it. i hear it definitely is the biggest one in the family and should be able to flow real good. since it's new, i wonder how it'll function.
Old Nov 18, 2001 | 10:42 PM
Hybrid ctr's Avatar
Default Re: ANYONE KNOW ABOUT T04X TURBO??? (InfamousCivic)
what's XS Engineering's website ???
TIA
Old Nov 18, 2001 | 10:55 PM
BoostinDC2's Avatar
Default Re: ANYONE KNOW ABOUT T04X TURBO??? (Hybrid ctr)
xs-engineering.com
pv2dickman
Oct 29, 2005 09:09 PM
tygsr
Jan 21, 2003 12:12 PM
01nhbgsr
Jun 10, 2002 06:36 PM
91cvcsi
Jun 4, 2002 12:33 AM
boosted3g
Oct 24, 2001 12:10 PM
