obd0--->obd1 or obd2?
Old Jun 16, 2004 | 03:09 PM
typeeg's Avatar
Default obd0--->obd1 or obd2?
I am currently running a b18c1 in my obd0 91 civic hatch.
My motor is from a 98 gsr so it was originally obd2.
Should I convert to obd1 or obd2?
What parts will I need to upgrade if I go to either one?
I'm guessing o2 sensor, distributor?
Old Jun 16, 2004 | 07:04 PM
B16A1-EF9's Avatar
Default Re: obd0--->obd1 or obd2? (StockEG9)
I would say OBD1. You'll need distributor, obd1 or 2. Make sure if you have the b18c injectors that your not running the injector resistor box, run an 0bd1 p72 computer and you'll need the 02 aswell. other then that your all set.
Oh also, get the obd0-obd1 plug from someone like LOCASHRACING or something...they are pretty good from what I hear.
Old Jun 16, 2004 | 07:07 PM
wickedEFguy's Avatar
well since the P72 is OBD1 your going to have to convert to OBD1 anyways.
Old Jun 17, 2004 | 04:45 AM
philipkrotch's Avatar
stay obd1.
Old Jun 17, 2004 | 05:59 AM
civicgsr's Avatar
Default Re: obd0--->obd1 or obd2? (wickedEFguy)
The P72 can be OBDI or OBDII...or even OBDII version 2. The nice thing about the '98 though, is that it has the same harness as the OBDI '94 and '95.
It would be smarter, much smarter, to go OBDI. Aside from going with an AEM ECU, you can have the OBDI modified by Hondata, whereas the OBDII ECU cannot be modified. Something to think about if you are going to do some heavier mods in the future.
Good luck!
Alex
Old Jun 17, 2004 | 12:10 PM
boomslang's Avatar
Convert to OBD1. OBD2 would be a big headache.
Old Jun 17, 2004 | 12:42 PM
typeeg's Avatar
Default Re: obd0--->obd1 or obd2? (boomslang)
Why would an obd0 ecu not work with an obd1 or obd2 distributor when an obd1 ecu will work with both?
Old Jun 18, 2004 | 10:49 AM
boomslang's Avatar
Default Re: obd0--->obd1 or obd2? (BrokenEF9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrokenEF9 &raquo;</TD></TR><TR><TD CLASS="quote">Why would an obd0 ecu not work with an obd1 or obd2 distributor when an obd1 ecu will work with both?</TD></TR></TABLE>
It has to do with internal differences of the distributors. OBD0 have 16 teeth. OBD1 and OBD2 have 24 teeth.
Old Jun 18, 2004 | 08:35 PM
Joseph Davis's Avatar
Default Re: obd0--->obd1 or obd2? (civicgsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicgsr &raquo;</TD></TR><TR><TD CLASS="quote">you can have the OBDI modified by Hondata</TD></TR></TABLE>
Hondata isn't the only person who can modify an OBD1 ECU - there are plenty of low rent kids out there modifying their own.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicgsr &raquo;</TD></TR><TR><TD CLASS="quote">whereas the OBDII ECU cannot be modified</TD></TR></TABLE>
It can't?
Old Jun 22, 2004 | 07:17 AM
JOeS's Avatar
I have a stock Euro Honda CRX 1.6VT (SiR) with a B16A1/PW0 and want to convert from OBD0 to OBD1.
Do I need to replace my OBD0 distributor an injectors?
I don't have a swap in my CRX, it's a standard European Honda CRX with a B16A1.
Old Jun 22, 2004 | 07:41 AM
boomslang's Avatar
Default Re: obd0--->obd1 or obd2? (JOeS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JOeS &raquo;</TD></TR><TR><TD CLASS="quote">
I don't have a swap in my CRX, it's a standard European Honda CRX with a B16A1.</TD></TR></TABLE>
Just your distributor.
Old Jun 22, 2004 | 07:43 AM
typeeg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boomslang &raquo;</TD></TR><TR><TD CLASS="quote">
Just your distributor.</TD></TR></TABLE>
You sure about this? I thought you need..
obd1 distributor, injectors, o2 sensor, and ecu?
Old Jun 22, 2004 | 08:36 AM
JOeS's Avatar
obd1 distributor, injectors, o2 sensor, and ecu?</TD></TR></TABLE>
Ok, thanx. I already thought so, I guess I got confused because someone said on the forum that the distibutor wasn't necessary...
So I need:
- OBD1 ECU like P28/P30 (for Uberdata)
- OBD0 -&gt; OBD1 conversion harness
- OBD1 distibutor
- 4-wire Honda O2-sensor
I can keep the OBD0 injectors because there's already a resistor box, right?
Old Jun 22, 2004 | 09:10 AM
CHEETAH's Avatar
you have to convert/address other things as well, i.e. VSS sensor signal to obd1 ecu, o2 sensor wiring for 4 wire or locating a 1 wire close enough to head via custom bung on header in order to heat up the element.
locash's harness is good i use them, he's cheap too.
Greg
Old Jun 22, 2004 | 10:14 AM
boomslang's Avatar
Yes, you need a 4-wire O2 sensor and obviously an ecu.
Old Jun 22, 2004 | 01:17 PM
typeeg's Avatar
Yes, you need a 4-wire O2 sensor and obviously an ecu.</TD></TR></TABLE>
what about the injectors though? dont you need obd1 injectors if you want to convert from obd0 to obd1?
Old Jun 22, 2004 | 08:23 PM
boomslang's Avatar
You can keep the OBD0 injectors if you retain the factory resistor box. OR you can use OBD1 injectors and remove the resistor box. Either way works fine.
Old Jun 23, 2004 | 01:00 AM
There's actually (admittedly minor for such small injectors) a difference in injector opening times and duration of fuel flow - most disparate when comparing @ idle versus the higher revs - when using a high Z injector driver to open a high Z injector and using a high Z injector driver to open a low Z injector across a **** box. Er, resistor box, sorry
Not that I haven't run high Z OBD1+ injectors on an OBD0 ECU, stock program, with good results. It's "close enough," you only see big problems esp with idle quality when you start running the big guns across a fu- er, resistor box.
Old Jun 24, 2004 | 02:00 AM
JOeS's Avatar
Default Re: obd0--->obd1 or obd2? (J. Davis)
Now, I'm confused. They talk about a G00 ECU over here:
https://honda-tech.com/zerothread?id=249451
1. I have a Euro ECU PW0 and I want to do the conversion. But apparently I cannot use a US ECU P28/P30? Or can I?
2. I know that the US spec has a knock sensor where the Euro has not. But I can disable that with Uberdata, right?
Can someone help me out?
Old Jun 24, 2004 | 02:56 AM
Accord2NR's Avatar
stay odb1.
Old Jun 24, 2004 | 02:59 AM
JOeS's Avatar
Default Re: obd0--->obd1 or obd2? (AcuraINTEGRALS)
Who? The topic is about conversion from OBD0 to OBD1 or OBD2.
Old Jun 24, 2004 | 03:47 AM
Accord2NR's Avatar
oh i mean conver to odb1.
Old Jun 24, 2004 | 06:56 AM
91civicDXdude's Avatar
to convert from OBDII to OBD1, all you need is an ECU conversion harness and OBD1 ECU, so im assuming that the OBDII injectors/distributor/sensors are compatible with an OBD1 ECU.
JdM_Eg6_SiiR
Engine Management and Tuning
Dec 6, 2010 07:12 AM
so simple
Mar 3, 2007 08:12 PM
N hatch
Jul 14, 2004 09:52 PM
1man
Jul 21, 2003 11:45 AM
hatchy
Mar 31, 2002 08:24 AM
