What Chip Map Settings is best for P28 SOHC VTEC?
Old Jun 4, 2004 | 09:05 PM
AsianEJ1Guy's Avatar
Default What Chip Map Settings is best for P28 SOHC VTEC?
What do you all think is best for a D16z6 and P28 ECU?
I need a new chip so help me choose, since you H-T guys had more experience.
I have all the bolt-ons you can imagine....from CAI to Catback...etc...
And it's a All Motor setup..
Modified by AsianEJ1Guy at 6:57 AM 6/5/2004
Old Jun 4, 2004 | 09:26 PM
jdmsiR20's Avatar
Default Re: What Chip Map Settings is best for P28 SOHC VTEC? (AsianEJ1Guy)
first off... what kind of mods do you have? i/h/e is not necessary, but strongly strongly recommended before you start tuning/modifying the ecu.
Old Jun 4, 2004 | 09:54 PM
Default Re: What Chip Map Settings is best for P28 SOHC VTEC? (jdmsiR20)
I have all bolt-ons, and full suspension tein SS coilovers.
Old Jun 4, 2004 | 09:56 PM
Luserkid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AsianEJ1Guy &raquo;</TD></TR><TR><TD CLASS="quote">I have all bolt-ons, and full suspension tein SS coilovers.</TD></TR></TABLE>
You dont need one of these chips because they change your settings for real race applications. Once you get a cam or pistons or build the head/block/both then look into a chip. Until then you have no reason to.
When you do build i would go with Skunk2 (but that is better with Skunk2 parts of course)
Old Jun 4, 2004 | 10:22 PM
jdmsiR20's Avatar
Default Re: What Chip Map Settings is best for P28 SOHC VTEC? (Luserkid)
taken from user 'eg6ajk'... his website is http://www.hyperducktuning.com.... sells chips and ecu tuning... please let me know you want it removed
:: P08/P28/P71/P91 : 92-5 Civic Si/EX/VTi (D16Z6/JDM D15B SOHC VTEC)
XS program
VTEC: 5000rpm
Rev limit: 8500rpm
Dyno/Tests: Street Program, good power, 2-6whp improvements after VTEC, works only on the USDM P28 ECU.
GUDE program
VTEC: 4900rpm
Rev limit: 7900rpm
Dyno/Tests: Street Program, good power, runs rather on rich side, good for bolt on and a mild cam. For USDM P28 only.
Spoon program
VTEC: 4600rpm
Rev limit: 7800rpm
Dyno/Tests: Very streetable program. Makes excellent power through out. Little on the richer side while idling and cruising.
RPT program
VTEC: 4200 or 4800rpm
Rev limit: 7800 or 9000rpm
Dyno/Tests: One of the better SOHC VTEC programs. Excellent power after VTEC, good for the Zex cam upgrade. Low-end seems to suffer a little but low VTEC and after VTEC power makes it up. For D15B SOHC VTEC only.
Prospeed program
VTEC: 4400rpm or 4800rpm
Rev limit: 7600 or 8700rpm
Dyno/Tests: Runs farily rich, seems to make excellent power. Gas mileage is less then average for race/street program. Made most power on D16Z6 with bolt-ons. 4-6whp through out and 5-7lbs of torque.
edit: it looks as if the programs you listed above as selections may be for dohc vtec setups?
Old Jun 4, 2004 | 11:28 PM
nwdave's Avatar
I've heard nothing but good things about Kenji's programs. Do a search on his name you'll find some info
Old Jun 5, 2004 | 07:56 AM
come on everyone vote.....
Old Jun 5, 2004 | 08:32 AM
senpai's Avatar
stock p28 with only bolt-ons
Old Jun 5, 2004 | 08:42 AM
Mr Hammond's Avatar
a/k/a Jomo
I don't see Kenji's on there. You should PM him. He'll set you up.
Old Jun 5, 2004 | 10:09 AM
AzntaggeR's Avatar
TSPeed Factory
Default Re: What Chip Map Settings is best for P28 SOHC VTEC? (nw.dave)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nw.dave &raquo;</TD></TR><TR><TD CLASS="quote">I've heard nothing but good things about Kenji's programs. Do a search on his name you'll find some info </TD></TR></TABLE>
yeah that's what i got
if you're going to pick from the list above i'd go with the JUN program.
Old Jun 5, 2004 | 10:11 AM
kingSfit's Avatar
skunk baby skunk =0)
Old Jun 5, 2004 | 11:26 AM
Jim Truett's Avatar
Default Re: (Bunz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bunz &raquo;</TD></TR><TR><TD CLASS="quote">skunk baby skunk =0)</TD></TR></TABLE>
The Skunk program has way too much fuel for a Z6. I recommend a custom tune for your setup with a freeware editor like Crome or Uberdata.
Skunk2 low cam fuel:
Stock P28 low cam fuel:
Modified by Jim Truett at 8:38 PM 6/5/2004
DO/\/\O
Jan 7, 2012 11:14 PM
dr@ke
15
Oct 27, 2006 09:46 PM
spooned out
Aug 6, 2005 09:07 AM
JDMSiGuy17
Oct 27, 2004 04:57 AM
Civic
Nov 22, 2003 01:16 AM
